Ga door naar hoofdinhoud
Motorola Moto Q Keyboard Replacement
Wat je nodig hebt
  1. Motorola Moto Q Keyboard Replacement, Back Casing: stap 1, afbeelding 1 van 1
    • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Be careful not to poke yourself when handling the push pin because it is very sharp.
  2. Motorola Moto Q Keyboard Replacement: stap 2, afbeelding 1 van 1
    • Use the T6 screwdriver to remove the four screws holding the casing together.
    • Note: they are in the same place where you removed the four rubber coverings
  3. Motorola Moto Q Keyboard Replacement: stap 3, afbeelding 1 van 2 Motorola Moto Q Keyboard Replacement: stap 3, afbeelding 2 van 2
    • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
    • Note: the phone should be face up and the plastic opening tool should be face downwards
    • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
    • Repeat the 3 steps above for the top, bottom, and opposite side.
  4. Motorola Moto Q Keyboard Replacement: stap 4, afbeelding 1 van 2 Motorola Moto Q Keyboard Replacement: stap 4, afbeelding 2 van 2
    • Gently lift and remove the back casing.
  5. Motorola Moto Q Keyboard Replacement, Camera: stap 5, afbeelding 1 van 2 Motorola Moto Q Keyboard Replacement, Camera: stap 5, afbeelding 2 van 2
    • Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
    • Gently rotate/wiggle the cover until you can pull it off the phone.
  6. Motorola Moto Q Keyboard Replacement: stap 6, afbeelding 1 van 2 Motorola Moto Q Keyboard Replacement: stap 6, afbeelding 2 van 2
    • Using your fingers, remove the plastic piece that holds the camera in place.
  7. Motorola Moto Q Keyboard Replacement: stap 7, afbeelding 1 van 2 Motorola Moto Q Keyboard Replacement: stap 7, afbeelding 2 van 2
    • Carefully pry up the upper circuit board with the spudger.
    • The second picture shows what your phone should look like when the upper circuit board is removed.
  8. Motorola Moto Q Keyboard Replacement: stap 8, afbeelding 1 van 2 Motorola Moto Q Keyboard Replacement: stap 8, afbeelding 2 van 2
    • Take out the camera and attached chip with the iPod removal tool. Carefully pry the chip off its connection and the camera will come out too.
  9. Motorola Moto Q Keyboard Replacement, Keyboard: stap 9, afbeelding 1 van 3 Motorola Moto Q Keyboard Replacement, Keyboard: stap 9, afbeelding 2 van 3 Motorola Moto Q Keyboard Replacement, Keyboard: stap 9, afbeelding 3 van 3
    • The keyboard is held in place with a little bit of glue.
    • Simply lift the keyboard buttons with your hands pulling from one side to the other.
Conclusie
Luis Herrera
52 Reputatie
4 handleidingen geschreven
Cal Poly, Team 16-33, Maness Winter 2010 Lid van Cal Poly, Team 16-33, Maness Winter 2010
CPSU-MANESS-W10S16G33
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 4,097
