Ga door naar hoofdinhoud
Inleiding
This guide’s easy to follow steps show how to access and remove the speaker for the Motorola Moto G7 Plus (model XT1965). The default speaker can produce noise levels up to 72dB and a ringer level of 84 dB.
Before starting, check the list of tools that you will need. Ensure the device is turned off and not connected to any power sources.
To replace the speaker, a compatible replacement is required.
  1. Insert an opening pick under the screen, starting at the top of the phone. Work the pick along the edges of the phone, removing adhesive from these parts of the screen.
    • Insert an opening pick under the screen, starting at the top of the phone.
    • Work the pick along the edges of the phone, removing adhesive from these parts of the screen.
    • There is a cable on the right side of the phone (the side with the volume buttons), which connects the screen to the rest of the phone. Be careful not to sever this cable.
    • Once enough adhesive has been removed, you should be able to separate the screen, gently lifting from the left side of the phone.
    • While not necessary, applying a heat gun will weaken the adhesive, making this step easier.
  2. Remove the three 2.7 mm screws that surround the base of the cable using the Torx T5 screwdriver. Once the screws have been removed, gently remove the metal piece that covers the base of the cable.
    • Remove the three 2.7 mm screws that surround the base of the cable using the Torx T5 screwdriver.
    • Once the screws have been removed, gently remove the metal piece that covers the base of the cable.
  3. Use the pointy end of the spudger to lift the metal casing where circled. The device is rotated 90 degrees Counterclockwise from original orientation.
    • Use the pointy end of the spudger to lift the metal casing where circled.
    • The device is rotated 90 degrees Counterclockwise from original orientation.
  4. Underneath this metal piece is the base of the cable. Use your pick or spudger to pop off the base of the cable. The screen will be detached from the device.
    • Underneath this metal piece is the base of the cable. Use your pick or spudger to pop off the base of the cable.
    • The screen will be detached from the device.
    • The device is rotated 180 degrees from original orientation.
  5. Use the Torx T5 screwdriver to remove the three 3.0 mm screws. Use the Torx T5 screwdriver to remove the three 3.0 mm screws.
    • Use the Torx T5 screwdriver to remove the three 3.0 mm screws.
  6. Use the spudger to lift up the right side of the speaker and remove the speaker from the device. A medium amount of force may be required. A medium amount of force may be required.
    • Use the spudger to lift up the right side of the speaker and remove the speaker from the device.
    • A medium amount of force may be required.
Conclusie
Javier Guerra
237 Reputatie
1 Handleiding geschreven
Cal Poly, Team S22-G5, Regan Winter 2020 Lid van Cal Poly, Team S22-G5, Regan Winter 2020
CPSU-REGAN-W20S22G5
5 Leden
13 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 42
Altijd: 1,056
