Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Insert an opening pick under the screen, starting at the top of the phone.
Work the pick along the edges of the phone while placing them in the corners.
After placing the picks along the edge of the screen, refer to step 2.
Loosen the adhesive by cutting along the sides of the phone with the Jimmy Knife and prop open the back.
The fingerprint sensor is now visible and can be replaced.
Remove the sensor cable with the metallic cover on top.
Use the pick to pry off the white plastic piece that holds the volume and power buttons in place.
Use the spudger to hook under the volume button to remove it.
Using the spudger, hook the top of the power button hooking to remove it.
Één andere persoon heeft deze handleiding voltooid.
