Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Insert an opening tool pick under the screen, starting at the top of the phone.
Slide the pick around the entire perimeter of the display to break the adhesive.
Once enough adhesive has been removed, you should be able to separate the screen by gently lifting it from the left side of the phone.
Remove the three 2.7 mm screws that surround the base of the display cable using the Torx T5 screwdriver.
Gently remove the metal piece that covers the base of the display cable.
Use the pointed end of the spudger to lift the metal casing where circled.
Underneath this metal piece is the base of the cable. Use a spudger to vertically lift the connection out of its port.
Remove the eleven screws with the T5 Torx screwdriver.
Remove the camera housing plate with the opening tool.
Disconnect the three highlighted connectors as seen in the diagram using the opening tools.
Pry the motherboard away from the frame of the phone using the opening tools.
Remove the camera from the motherboard.
