Ga door naar hoofdinhoud
Motorola Moto G7 Plus Front Camera Replacement
Wat je nodig hebt
  1. Motorola Moto G7 Plus Front Camera Replacement, Remove the Screen: stap 1, afbeelding 1 van 2 Motorola Moto G7 Plus Front Camera Replacement, Remove the Screen: stap 1, afbeelding 2 van 2
    • Insert an opening tool pick under the screen, starting at the top of the phone.
    • Slide the pick around the entire perimeter of the display to break the adhesive.
    • There is a cable on the right side of the phone (the side with the volume buttons), which connects the screen to the rest of the phone. Be careful not to damage this cable.
    • Once enough adhesive has been removed, you should be able to separate the screen by gently lifting it from the left side of the phone.
    • While not necessary, applying a gentle heat to the edges of the display with a heat gun or iOpener will weaken the adhesive.
  2. Motorola Moto G7 Plus Front Camera Replacement, Remove the Display Cable Cover: stap 2, afbeelding 1 van 2 Motorola Moto G7 Plus Front Camera Replacement, Remove the Display Cable Cover: stap 2, afbeelding 2 van 2
    • Remove the three 2.7 mm screws that surround the base of the display cable using the Torx T5 screwdriver.
    • Gently remove the metal piece that covers the base of the display cable.
  3. Motorola Moto G7 Plus Front Camera Replacement: stap 3, afbeelding 1 van 2 Motorola Moto G7 Plus Front Camera Replacement: stap 3, afbeelding 2 van 2
    • Use the pointed end of the spudger to lift the metal casing where circled.
  4. Motorola Moto G7 Plus Front Camera Replacement, Separate the Display From the Phone: stap 4, afbeelding 1 van 2 Motorola Moto G7 Plus Front Camera Replacement, Separate the Display From the Phone: stap 4, afbeelding 2 van 2
    • Underneath this metal piece is the base of the cable. Use a spudger to vertically lift the connection out of its port.
  5. Motorola Moto G7 Plus Front Camera Replacement, Front Camera: stap 5, afbeelding 1 van 1
    • Remove the eleven screws with the T5 Torx screwdriver.
  6. Motorola Moto G7 Plus Front Camera Replacement: stap 6, afbeelding 1 van 2 Motorola Moto G7 Plus Front Camera Replacement: stap 6, afbeelding 2 van 2
    • Remove the camera housing plate with the opening tool.
  7. Motorola Moto G7 Plus Front Camera Replacement: stap 7, afbeelding 1 van 1
    • Disconnect the three highlighted connectors as seen in the diagram using the opening tools.
  8. Motorola Moto G7 Plus Front Camera Replacement: stap 8, afbeelding 1 van 2 Motorola Moto G7 Plus Front Camera Replacement: stap 8, afbeelding 2 van 2
    • Pry the motherboard away from the frame of the phone using the opening tools.
    • Do not completely remove the motherboard from the device.
    • Remove the camera from the motherboard.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 680
