Ga door naar hoofdinhoud
Motorola Moto G7 Play Camera Replacement
Wat je nodig hebt
  1. Motorola Moto G7 Play Camera Replacement, Back Cover: stap 1, afbeelding 1 van 2 Motorola Moto G7 Play Camera Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Turn off your device before you begin.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case. If you're using the iOpener, please review the instructions for proper use.
  2. Motorola Moto G7 Play Camera Replacement: stap 2, afbeelding 1 van 1
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  3. Motorola Moto G7 Play Camera Replacement: stap 3, afbeelding 1 van 2 Motorola Moto G7 Play Camera Replacement: stap 3, afbeelding 2 van 2
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
  4. Motorola Moto G7 Play Camera Replacement, Camera: stap 4, afbeelding 1 van 1
    • Remove the nine 3.2mm screws from the motherboard cover with a Phillips #00 screwdriver.
  5. Motorola Moto G7 Play Camera Replacement: stap 5, afbeelding 1 van 1
    • Lift the motherboard cover from the bottom.
    • Use reverse tweezers or a similar tool if needed.
  6. Motorola Moto G7 Play Camera Replacement: stap 6, afbeelding 1 van 2 Motorola Moto G7 Play Camera Replacement: stap 6, afbeelding 2 van 2
    • Once the motherboard cover is removed, use the iFixit opening tool to disconnect the ribbon cable connecting the camera to the motherboard.
    • The camera can now be removed and is ready to be replaced.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Monserath Casillas
1.146 Reputatie
5 handleidingen geschreven
Cal Poly, Team S7-G4, Regan Winter 2020 Lid van Cal Poly, Team S7-G4, Regan Winter 2020
CPSU-REGAN-W20S7G4
5 Leden
12 handleidingen geschreven
Één opmerking
My camera stopped working after water damage. Replacing the camera itself didn’t fix it. What could the problem be?
abb - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 925
