Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Bring the heat gun one to two inches from the edges of the display to melt the display adhesive.
Spend equal amounts of time applying heat around the entire edge of the phone.
Attach the suction cup to the display slightly to the left of center.
Exert a moderate force to pull on the suction cup. The display will come loose.
Insert the opening tool inside the loosened edge.
Gradually work the opening tool around the edge of the entire screen to cut through the adhesive.
Press down on the fingerprint sensor with the display slightly raised to disconnect it from the display.
Remove the one 5mm Torx-5 screw located by the connector cables in the top right corner of the device.
Gereedschap gebruikt in deze stap:Tweezers$4.99-
Grab the unscrewed metal plate with your blunt tweezers.
Slide the metal plate to the left and then out to remove it.
Disengage the two cable connectors by gently prying beneath the edge of the connector with the opening tool.
Lift up the detached right connector from its housing using blunt tweezers.
Remove the nine black 5mm Torx-5 screws.
Remove the seven silver 5mm Torx-5 screws.
Remove the metal cover by prying underneath it with the opening tool.
Grab ahold of the fingerprint sensor and push it through the opening in the metal cover.
Remove the fingerprint connector by gently prying underneath the connector with the opening tool.
The battery is now fully exposed and ready to be removed.
Use the opening tool to remove the two metal connectors located above the battery.
Apply a gentle upward pressure to loosen the metal plates.
Using the spudger, cut downwards along the black tape on left side of the battery.
Use the opening tool to disengage the black connector located above the battery.
Use the heat gun along the back of the phone to loosen the adhesive that holds the battery in place.
Spend equal intervals of time on each area applying heat.
Insert the spudger underneath the right side of the battery.
Apply a moderate upward force along the length of battery, until the battery lifts out of place.
Remove the battery with your hand.
11 andere personen hebben deze handleiding voltooid.
