Inleiding
The battery in the Motorola Moto G5s is sealed inside the phone housing. In the instance that you have to replace a faulty battery, there is a specific procedure that you have to follow.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Wat je nodig hebt
Bring the heat gun one to two inches from the edges of the display to melt the display adhesive.
Spend equal amounts of time applying heat around the entire edge of the phone.
Remove the nine black 5mm Torx-5 screws.
Remove the seven silver 5mm Torx-5 screws.
11 andere personen hebben deze handleiding voltooid.
