Ga door naar hoofdinhoud
Motorola Moto G5 Vibration Motor Replacement
Wat je nodig hebt
  1. Motorola Moto G5 Vibration Motor Replacement, Back Cover: stap 1, afbeelding 1 van 2 Motorola Moto G5 Vibration Motor Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Vibration Motor Replacement: stap 2, afbeelding 1 van 3 Motorola Moto G5 Vibration Motor Replacement: stap 2, afbeelding 2 van 3 Motorola Moto G5 Vibration Motor Replacement: stap 2, afbeelding 3 van 3
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Vibration Motor Replacement: stap 3, afbeelding 1 van 3 Motorola Moto G5 Vibration Motor Replacement: stap 3, afbeelding 2 van 3 Motorola Moto G5 Vibration Motor Replacement: stap 3, afbeelding 3 van 3
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Vibration Motor Replacement: stap 4, afbeelding 1 van 2 Motorola Moto G5 Vibration Motor Replacement: stap 4, afbeelding 2 van 2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Vibration Motor Replacement, Battery: stap 5, afbeelding 1 van 2 Motorola Moto G5 Vibration Motor Replacement, Battery: stap 5, afbeelding 2 van 2
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Vibration Motor Replacement: stap 6, afbeelding 1 van 1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
  7. Motorola Moto G5 Vibration Motor Replacement, Vibration Motor: stap 7, afbeelding 1 van 1
    • Remove the nine (9) 4mm Philips screws securing the daughterboard cover.
  8. Motorola Moto G5 Vibration Motor Replacement: stap 8, afbeelding 1 van 1
    • Remove the plastic casing on the bottom of the phone by gently pulling.
  9. Motorola Moto G5 Vibration Motor Replacement: stap 9, afbeelding 1 van 3 Motorola Moto G5 Vibration Motor Replacement: stap 9, afbeelding 2 van 3 Motorola Moto G5 Vibration Motor Replacement: stap 9, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the three connectors on the board below the battery slow by gently pulling on the small gold tab with a pair of tweezers.
  10. Motorola Moto G5 Vibration Motor Replacement: stap 10, afbeelding 1 van 1
    • Remove the 3.4 mm Philips screw securing the daughterboard to the frame.
  11. Motorola Moto G5 Vibration Motor Replacement: stap 11, afbeelding 1 van 1
    • Use the point of a spudger to lift the vibration motor connector up out of the socket on the I/O board.
    • Be very careful to pry only on the connector under the red and black cables, not on the socket itself.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Miles Cobb
370 Reputatie
1 Handleiding geschreven
Cal Poly, Team S2-G3, Livingston Winter 2018 Lid van Cal Poly, Team S2-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G3
4 Leden
16 handleidingen geschreven
Één opmerking
Is this also where the mic is located?
Matt - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 23
Altijd: 3,435
