Inleiding
The home button on the Motorola Moto G5 plus can stop working. If you find the home button sticks and is unresponsive, use this guide to replace it with a new one.
Wat je nodig hebt
Use a SIM eject bit, SIM eject tool, or paper clip to remove the SIM card from your phone.
Prepare an iOpener and heat the front of the phone along its left edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the display.
Apply a suction cup to the display, near the middle of the left edge.
Pull the suction cup with firm, constant pressure to create a slight gap between the display panel and the rear case.
If the display doesn't separate even with significant force, apply more heat to further soften the adhesive and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
Remove the fingerprint sensor button from the screen by pushing it out with your fingers.
4 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Any way to just clean the edges of the sensor without taking apart the entire phone?
Finger print scanner connector port get completely damaged. is this the reason my phone is not getting started
