Ga door naar hoofdinhoud
Motorola Moto G5 Motherboard Replacement
Wat je nodig hebt
  1. Motorola Moto G5 Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 2 Motorola Moto G5 Motherboard Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Motherboard Replacement: stap 2, afbeelding 1 van 3 Motorola Moto G5 Motherboard Replacement: stap 2, afbeelding 2 van 3 Motorola Moto G5 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Motherboard Replacement: stap 3, afbeelding 1 van 3 Motorola Moto G5 Motherboard Replacement: stap 3, afbeelding 2 van 3 Motorola Moto G5 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Motherboard Replacement: stap 4, afbeelding 1 van 2 Motorola Moto G5 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Motherboard Replacement, Battery: stap 5, afbeelding 1 van 2 Motorola Moto G5 Motherboard Replacement, Battery: stap 5, afbeelding 2 van 2
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
  7. Motorola Moto G5 Motherboard Replacement, Rear Facing Camera: stap 7, afbeelding 1 van 2 Motorola Moto G5 Motherboard Replacement, Rear Facing Camera: stap 7, afbeelding 2 van 2
    • Remove the eight (8) 4mm screws with a Phillips screwdriver.
  8. Motorola Moto G5 Motherboard Replacement: stap 8, afbeelding 1 van 3 Motorola Moto G5 Motherboard Replacement: stap 8, afbeelding 2 van 3 Motorola Moto G5 Motherboard Replacement: stap 8, afbeelding 3 van 3
    • Pry the top motherboard cover off using a plastic opening tool.
    • When prying it open, make sure to pry it around evenly so that the cover will not snap. This will require some force.
  9. Motorola Moto G5 Motherboard Replacement: stap 9, afbeelding 1 van 3 Motorola Moto G5 Motherboard Replacement: stap 9, afbeelding 2 van 3 Motorola Moto G5 Motherboard Replacement: stap 9, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Disconnect the marked connector with a pair of tweezers and remove the camera piece.
  10. Motorola Moto G5 Motherboard Replacement, Motherboard: stap 10, afbeelding 1 van 1
    • Remove the two 4mm screws shown in the picture using a Phillips #00 screwdriver.
  11. Motorola Moto G5 Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Lift the motherboard up from the top of the phone.
  12. Motorola Moto G5 Motherboard Replacement: stap 12, afbeelding 1 van 1
    Koop
    • Unplug the back connector from the motherboard using tweezers.
Conclusie
11 andere personen hebben deze handleiding voltooid.
Luis Garcia
307 Reputatie
1 Handleiding geschreven
Cal Poly, Team S2-G3, Livingston Winter 2018 Lid van Cal Poly, Team S2-G3, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G3
4 Leden
16 handleidingen geschreven
2 opmerkingen
is a xt1670 logic board compatible with a xt1671 phone?
Jaime Oziel Moreno - Antwoord
While disassembling I accidentally broke off one of the antenna "pins" (the one under the audio jack). I'll try to solder it on again, but in case I cannot, you think it will affect its proper operation too much? I cannot test it right now as I am waiting a replacement side buttons board.
karajay - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 42
Altijd: 6,301
