Inleiding
This guide demonstrates how to remove the battery from a Motorola Moto G Power (2020) cellphone.
Before you begin, download the Software Fix app to backup your device and diagnose whether your problem is software or hardware related.
If you have been dealing with issues related to your phone holding a charge consistently, this guide will help breathe some new life into your phone with a new replacement battery!
This guide will walk you through the process of extracting all of the hardware necessary to replace the battery while also helping you to avoid any potential damage that occur.
*Some knowledge of technical terms for the inner hardware of electronics may be helpful.
*On step 8 pay careful attention as there is a risk of damage to your skin and clothing.
Wat je nodig hebt
Position a suction cup securely on the back panel of the device.
Insert the opening pick into both sides of the phone and carefully slide it along to open the back panel of the device.
If present, carefully remove the protective tape using a plastic spudger as shown, ensuring the delicate flex cable is not torn in the process.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Use a plastic spudger or non-conductive tweezers to disconnect the battery cable from the motherboard.
Slide an opening pick under the battery and gently work it back and forth to separate the adhesive from the battery.
Remove the old battery and insert the replacement battery, connecting it to the motherboard.
To reassemble your device, follow these instructions in reverse order, excluding the battery removal, of course.
7 andere personen hebben deze handleiding voltooid.
5Gids Commentaar
How hard would it be for phone manufacturers to create a back cover to access battery for replacement...but NO, they make it as difficult as possible so they can make money selling new phones and/or sell repair services.
I purchased my "not Motorola" KZ50 battery from an eBay seller, it was a drop-in replacement for the original battery. I did have to do my own "fold" for the flex cable, not a big deal. I used my own T3 screwdriver, the "free" tools included with the battery are worth what I paid for them.
This guide worked great for me! Thank you. However, a couple of suggestions to make it a bit better. On the first step, I had a little trouble separating the back. The back is attached with glue (the guide doesn't say this) and I wasn't exactly sure which grove on the edge was the back. And edge picture would be helpful. Also, while removing the back, most of the glue came off the back and was unusable for re-assembly. Some suggestion on how to deal with that would be helpful. I used a bit of double stick tape, which seems to work ok, but I'm mostly relying my protective phone case to hold it together.
Ok, I looked at some other guides on this site and found a great deal more detail and help. So while this guide worked, but it's pretty lacking in detail. Take a look at this one for example, and how much information it has about how to soften the adhesives, notes on re-assembling the connectors, and links to re-assembling adhesive-attached parts. Motorola Moto G Play (2021) Screen Replacement
