Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Use your fingernail to pry under the notch on the bottom of the phone and remove the back cover.
Evenly apply heat to the edges of the touchscreen to loosen the adhesive. Continue to Step 3 once the edge of the screen is warm to the touch.
As the adhesive loosens, pry up an edge of the screen with a plastic opening tool or an opening pick. A suction cup may also be useful here.
Use an opening pick to hold that edge in place and continue this process around the entire screen, applying more heat as necessary.
Gereedschap gebruikt in deze stap:Tesa 61395 Tape$5.99-
Use a plastic opening tool to flip up the lock on the display cable ZIF connector.
Pull the display cable from its socket on the motherboard.
Remove the ten 2.4 mm T4 screws from the sides of the motherboard.
Remove the four 4.5 mm T4 screws from the top and bottom of the motherboard.
If adhesive residue is holding the motherboard in place, use a Jimmy to cut the adhesive between the motherboard and the back of the phone.
Carefully lift the right edge of the motherboard from the phone.
Use a plastic opening tool to disconnect the battery wires from the motherboard.
Remove the three 2.4 mm T4 screws from the right side and bottom of the SIM/SD card panel.
Pry off the SIM/SD card panel using a plastic opening tool.
Pry off the main camera from its base using a plastic opening tool.
Use a plastic opening tool to flip up the lock on the camera cable ZIF connector.
Carefully pull the camera from its socket on the motherboard.
3 andere personen hebben deze handleiding voltooid.
