Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove back cover. It's easy, no adhesive and no screws.
Twist off all 14 screws together and remove the back frame easily. But the screws feature different lengths, you'd better remember their positions.
Release SIM&SD card reader connector and battery connector. And get the vibrator motor free from adhesive.
Loosen the platinum foil under SIM & SD card reader from plate. And then drag the stickers out which fix the battery.
At that time, remove the battery with SIM & SD card reader assembly together.
Separate battery and SIM & SD card reader assembly.
Release sensor flex connector and front camera connector respectively.
Remove screws on the motherboard and the motherboard can be removed easily.
13 opmerkingen
Nice work!
REQUEST: Next time you do a cell phone would you also shoot a straight down on top shot. The 3/4 is nice but I want to look straight down !
TY
P.S. Or just do a single TOP VIEW at the END like this one from Dillon ! Pretty Please!
Top View -
My Moto G just burned with 12 V from a cheap auto-recharger. But I lost very important data on the 8 GB memory. Is there a possible way to save the data?
Where can I get more information about GPS module and its antenna?
