Ga door naar hoofdinhoud
Motorola Moto G 2nd Generation Battery Replacement
Wat je nodig hebt
  1. Motorola Moto G 2nd Generation Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Motorola Moto G 2nd Generation Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Motorola Moto G 2nd Generation Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Make sure your Moto G is turned off and that any SIM or SD cards are removed before beginning disassembly.
    • Starting at the USB port on the bottom, remove the rear cover by prying it off with your finger.
    • Work your way down the sides to avoid cracking the rear cover.
    Important - remove SIM cards before opening the phone.
    Wojciech Dyba - Antwoord
  2. Motorola Moto G 2nd Generation Battery Replacement: stap 2, afbeelding 1 van 3 Motorola Moto G 2nd Generation Battery Replacement: stap 2, afbeelding 2 van 3 Motorola Moto G 2nd Generation Battery Replacement: stap 2, afbeelding 3 van 3
    • Remove the eight 4.2 mm screws at the top and bottom of the phone using a T5 Torx screwdriver.
    • Using the same screwdriver, remove the six 3.2 mm screws on the sides.
    • Remove the next layer of the phone by prying it off with your fingers.
    On mine, they’re all Torx T5
    Stanley Reynolds - Antwoord
    You neglected to mention that the two buttons might fall out when you remove this part.
  3. Motorola Moto G 2nd Generation Battery Replacement: stap 3, afbeelding 1 van 3 Motorola Moto G 2nd Generation Battery Replacement: stap 3, afbeelding 2 van 3 Motorola Moto G 2nd Generation Battery Replacement: stap 3, afbeelding 3 van 3
    • Using a plastic opening tool or tweezers, disconnect the SIM/SD card reader at the top of the phone.
    • Disconnect the battery connector by prying it off of the motherboard.
    • Disconnect the vibration motor by prying its connector off of the motherboard.
    sir when I put on for charging it shows 50% charging after 1 hour when I removed the charger its showin 0 and total is dead. what is the reason
    leela - Antwoord
    moto g 2 completely dead what the reason
    leela - Antwoord
    There's no need to remove the battery or motherboard to get to the speakers - they are accessible as soon as the back cover is removed. Skip this step and jump straight to step 10
    Paul Abraham - Antwoord
    In fact it is not necessary to remove the simcard rack. I managed to remove battery with the rack on. It is possible to remove the foil startingfrom the bottom of the battery and once peeled off the battery can be removed. You only need to disconnect the battery from the mother board.
  4. Motorola Moto G 2nd Generation Battery Replacement: stap 4, afbeelding 1 van 3 Motorola Moto G 2nd Generation Battery Replacement: stap 4, afbeelding 2 van 3 Motorola Moto G 2nd Generation Battery Replacement: stap 4, afbeelding 3 van 3
    • Using a plastic opening tool, carefully pry off the entire SIM/SD card reader component.
    • Don't worry about ripping the copper foil a little bit, it is easy to put back on.
    • When reassembling the device, do not attempt to smooth the foil down with your finger. Metal foil can become sharp if folded in a certain way, and you may be cut.
    • The battery may be removed without removing the SIM/SD card reader. Simply peel back the copper foil from the opposite end of the device, stopping just before you reach the SIM/SD card reader.
    As mentioned in a comment on the previous step, you don’t actually need to remove the SIM/SD card reader at all.
    If you peel back the copper foil from the opposite end of the device, you can sneak the battery out (and the new battery in) by just sliding the battery ribbon cable out from under the SIM/SD card reader.
    David - Antwoord
    Thx for the idea. I’ll let you know if it was working - I’ll my battery soon. regards!
    ausssiefan - Antwoord
    Perfect as mentioned - just slide the cable foil under the sim rack - no need to remove the rack. Works flawlessly, quick repair.
    ausssiefan -
  5. Motorola Moto G 2nd Generation Battery Replacement: stap 5, afbeelding 1 van 3 Motorola Moto G 2nd Generation Battery Replacement: stap 5, afbeelding 2 van 3 Motorola Moto G 2nd Generation Battery Replacement: stap 5, afbeelding 3 van 3
    • Peel off the two black stickers on the right side of the battery using your fingers.
    • Remove the battery by pulling the right side of it upwards.
    • The black stickers are the protruding ends of the two parallel adhesive strips which hold the battery in place. You can see the adhesive strips in the third image. Focus your effort on these regions.
    • If you did not remove the SIM/SD card reader in the previous step, you will need to carefully slide the battery ribbon cable out from under it once you have freed the battery from the adhesive strips.
    HINT: The ‘two black stickers’ are the ends of the two parallel adhesive strips which hold the battery in. There is no other adhesive holding the battery, so focus your attention on these regions when prying the battery out!
    David - Antwoord
    If the copper foil is damaged beyond repair, what can be used to replace it?
    Xander Squier - Antwoord
Conclusie
50 andere personen hebben deze handleiding voltooid.
Alex Kubacki
1.909 Reputatie
1 Handleiding geschreven
Cal Poly, Team 1-19, Maness Fall 2015 Lid van Cal Poly, Team 1-19, Maness Fall 2015
CPSU-MANESS-F15S1G19
4 Leden
15 handleidingen geschreven
14 opmerkingen
It might be worth mentioning that when you remove the 'next layer' of the phone, the power and volume buttons are likely to fall out (I maybe panicked a little when the power button first fell out and I didn't immediately know what part of the phone it was). Especially since they're a pain to put back into place afterwards.
Johanna - Antwoord
Good guide and pictures, thank you, helped me complete the task. Worth reiterating comments above re power and volume buttons, be careful not to lose them and take note of which way up they go. Also note two different screw lengths, when reassembling be sure to put the correct length screws in the holes.
David - Antwoord
Should also mention that when reassembling, the 3.2mm screws down the sides need to be tightened very gently, otherwise the screw tips will press on the back of the LCD. If you're lucky this will cause a spot on the LCD and loosening the screw slightly will fix it. If you're unlucky the LCD will be destroyed.
Billmond - Antwoord
The instructions were just fine and I was able to replace the battery. HOWEVER, when I plugged the phone in to charge the replacement battery, the notification light came on steady and the phone didn't do anything else. I then replaced the purchased battery with the old one and the phone works again. I did buy the battery about 6 months ago and just installed it today. I'm not sure if the battery was bad from the start, if it deteriorates over time without being installed in a phone or what happened. All I know is the replacement battery didn't work and the old one does.
After this exercise, I certainly know how to replace the battery in a Moto G2!
Steve Garceau - Antwoord
Everything seemed to go Ok,except when I turned the phone on it has No “Network” connection. I contacted the phone company and they could not help.& I was advised to order a New phone. They said I must have broke something??
I`d appreciate any input.
Thanks
Ed-fsd2@cox.net
Ed Fisher - Antwoord
Replaced the power connector using these illustrations. No need to remove the battery or the battery connectors, but 3 PCB screw have to be removed along with the screen ribbon cable, which is removed like any other ribbon cable.
Not too bad of a job but you need hot air to R&R that surface-mounted power connector. I had a surface mount soldering station to do it and I wouldn’t recommend replacing the power connector without one.
mike.donnigan - Antwoord
This guide should mention that you should remove your SIM card and SD card from the reader before changing the battery.
Because I was following the instructions exactly I didn’t remove them first, and in removing the SIM/SD card reader I broke the SD card it contained :(. So be sure to remove SIM and SD card before starting this tutorial!
Willem - Antwoord
Hi Willem,
Sorry to hear that! The guide does mention SIM card removal in the first step. I will modify it so it stands out more.
Arthur Shi -
Hi Arthur, yeah, I added that info to the guide after I discovered the missing info. It wasn’t there before.
Willem -
Sorry about the misunderstanding and thanks for adding that into the guide!
Arthur Shi -
Thanks very much. This was a great guide. I just replaced the battery. Without your guide, I might have damaged something. The switches did fall out, The little switch tabs go on the up side (with the screen down).
Lloyd Gordon - Antwoord
Just one comment, when removing the SIM card connector. You need to pry it off the motherboard, I made the mistake of thinking it was plugged in, and tried to pull it out rather than pry it out. Otherwise worked out OK.
JohnB
John Batten - Antwoord
The battery shown works in earlier G2 models. I have an XT1072, which uses a battery with a twisted wire and narrow 2-pin slide connector much like the G3 batteries. Vendors have yet to confirm whether I can use say an FT40 (2200 mAh) that also fits Motorola E2 phones. My suspicion is Motorola/Google simply upgraded the battery midway through the series. But don’t buy the flat-pin connector style you see here until you’re sure.
Karin - Antwoord
Simply peel back the copper foil …
In the case where the foil is unuseable is it absolutely necessary to replace it, and if so, can anyone suggest a suitable material/supplier please?
Thanks.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 44
Altijd: 62,937
