Ga door naar hoofdinhoud
Motorola Moto G 1st Generation Headphone Jack Replacement
Wat je nodig hebt
  1. Voorzichtig: stappen 1-3 komen van een handleiding die in bewerking is.
    Motorola Moto G 1st Generation Headphone Jack Replacement, Rear Panel: stap 1, afbeelding 1 van 3 Motorola Moto G 1st Generation Headphone Jack Replacement, Rear Panel: stap 1, afbeelding 2 van 3 Motorola Moto G 1st Generation Headphone Jack Replacement, Rear Panel: stap 1, afbeelding 3 van 3
    • Before you start following any of the steps of this guide, completely turn the device off.
    • Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
  2. Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Screws: stap 2, afbeelding 1 van 1
    • Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
  3. Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Battery Cover: stap 3, afbeelding 1 van 2 Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Battery Cover: stap 3, afbeelding 2 van 2
    • Use a plastic opening tool to remove the protective cover.
    • Carefully work the plastic tool around all the edges of the phone.
    • The protective cover holds the Volume and the Home buttons which might fall off the assembly when the cover is removed.
  4. Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Headphone Jack: stap 4, afbeelding 1 van 3 Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Headphone Jack: stap 4, afbeelding 2 van 3 Motorola Moto G 1st Generation Headphone Jack Replacement, Removing the Headphone Jack: stap 4, afbeelding 3 van 3
    • Use the plastic opening tool to remove the Headphone Jack from the protective cover and replace it.
Conclusie
Radostin Lobodov
2.904 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014 Lid van UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S5G7
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 2,361
