Wat je nodig hebt
Stap 1 Rear Panel
Voorzichtig: stappen 1-3 komen van een handleiding die in bewerking is.
Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
Use a plastic opening tool to remove the protective cover.
Use the Pry tool to disconnect the Front Camera, found in the upper right corner, from the motherboard.
Remove the camera from the phone by using the tweezers.
To reassemble, follow the steps in reverse.
4 andere personen hebben deze handleiding voltooid.
