Ga door naar hoofdinhoud
Motorola Moto G 1st Generation Back Speaker Replacement
Wat je nodig hebt
  1. Motorola Moto G 1st Generation Back Speaker Replacement, Removing the Cover: stap 1, afbeelding 1 van 3 Motorola Moto G 1st Generation Back Speaker Replacement, Removing the Cover: stap 1, afbeelding 2 van 3 Motorola Moto G 1st Generation Back Speaker Replacement, Removing the Cover: stap 1, afbeelding 3 van 3
    • You can remove the outer cover on the back of the phone by using a plastic opening tool. After removal the inner back cover will be exposed as shown.
    • This part is moderately difficult, especially if you've never taken the outer back cover off before this point.
    • It may take you several tries, but please be patient. The cover is surprisingly flexible, but not enough to withstand a lot of pressure.
  2. Motorola Moto G 1st Generation Back Speaker Replacement: stap 2, afbeelding 1 van 1
    • Shut down the phone.
    • Push SIM card until it pops out.
    • Remove SIM card.
    • In some version of this phone, a microSD memory card can be installed. If so, you must also remove these cards.
    • Be careful as to not damage the microSD memory card. Unlike the SIM card, pushing this in may not spring release, as there may not be an eject mechanism.
    • If there is no spring release eject mechanism, hopefully your microSD card has a ridge/raised edge that you can push on with your fingernail or plastic/rubber tool to push the card out. This may be difficult - be patient and do not use excessive force/sharp tools that could cause permanent damage and permanent loss of data.
  3. Motorola Moto G 1st Generation Back Speaker Replacement, Removing the Back Plate: stap 3, afbeelding 1 van 3 Motorola Moto G 1st Generation Back Speaker Replacement, Removing the Back Plate: stap 3, afbeelding 2 van 3 Motorola Moto G 1st Generation Back Speaker Replacement, Removing the Back Plate: stap 3, afbeelding 3 van 3
    • Using a T5 Torx screwdriver head, take out the 14 screws (3.5 mm diameter and 5 mm long) that hold the back plate in place.
    • Make sure to keep all of the screws together, as they are very easily lost.
    • The magnetic project mat or a container is a great way to keep all the little metal screws as well as other small metal pieces from being lost.
  4. Motorola Moto G 1st Generation Back Speaker Replacement, The Inside of your Phone: stap 4, afbeelding 1 van 3 Motorola Moto G 1st Generation Back Speaker Replacement, The Inside of your Phone: stap 4, afbeelding 2 van 3 Motorola Moto G 1st Generation Back Speaker Replacement, The Inside of your Phone: stap 4, afbeelding 3 van 3
    • Use the plastic opening tool to take out the inner back cover after all the screws have been removed.
    • This will expose the motherboard and the attached battery.
    • Take note that once the inner back cover is removed the volume and power buttons on the side can easily fall out or be removed.
  5. Motorola Moto G 1st Generation Back Speaker Replacement, Locating the Speaker: stap 5, afbeelding 1 van 1
    • The back speaker will be located on the back plate. It is easily identified by a silver disc with a felt black middle. See it located in the yellow and red circle.
    • Looking at the back plate, it will be on the right.
  6. Motorola Moto G 1st Generation Back Speaker Replacement, Removing the Speaker: stap 6, afbeelding 1 van 3 Motorola Moto G 1st Generation Back Speaker Replacement, Removing the Speaker: stap 6, afbeelding 2 van 3 Motorola Moto G 1st Generation Back Speaker Replacement, Removing the Speaker: stap 6, afbeelding 3 van 3
    • For this procedure it is recommended to use the black plastic pick called a spudger shown in picture.
    • Using flat end, approach the speaker from top direction of case. Carefully and firmly wedge the flat end of spudger between where the speaker meets the case.
    • Gently push the speaker up. It may have some adhesive on the bottom to keep it in place, so some resistance is common.
    • If you find that the speaker is not coming up this is due to the adhesive. It may require multiple attempts, just take your time and stick with it. The area shown in the picture is what we found to be the easiest separation point.
  7. Motorola Moto G 1st Generation Back Speaker Replacement, End Result: stap 7, afbeelding 1 van 2 Motorola Moto G 1st Generation Back Speaker Replacement, End Result: stap 7, afbeelding 2 van 2
    • This is the speaker after removal.
    • To replace, line the new speaker up in the space the old one occupied. Gently press until the speaker fits snugly.
Conclusie
13 andere personen hebben deze handleiding voltooid.
Rebecca Montgomery
3.982 Reputatie
6 handleidingen geschreven
USF Tampa, Team 1-6, Brown Fall 2014 Lid van USF Tampa, Team 1-6, Brown Fall 2014
USFT-BROWN-F14S1G6
4 Leden
17 handleidingen geschreven
Één opmerking
Is this speaker the one that vibrate ?
simounours - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 10
Altijd: 7,005
