Ga door naar hoofdinhoud
Motorola Moto E6 Play Fingerprint Scanner Replacement
Wat je nodig hebt
  1. Motorola Moto E6 Play Fingerprint Scanner Replacement, Back Cover: stap 1, afbeelding 1 van 2 Motorola Moto E6 Play Fingerprint Scanner Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Run the halberd spudger along the edges of the device. The back cover should easily pop off.
    • Gently remove the back cover. Do not pull hard, as it is still connected to the fingerprint scanner inside the phone.
  2. Motorola Moto E6 Play Fingerprint Scanner Replacement, Circuit Board Covers: stap 2, afbeelding 1 van 2 Motorola Moto E6 Play Fingerprint Scanner Replacement, Circuit Board Covers: stap 2, afbeelding 2 van 2
    • To remove the cover on the motherboard, remove the 10 silver 3.90 mm Phillips screws attaching the cover to the board using the Phillips #0 screwdriver.
    • One of these ten screws is covered by black tape located at the bottom left corner of the black cover. Peel back the black tape to access this screw.
  3. Motorola Moto E6 Play Fingerprint Scanner Replacement: stap 3, afbeelding 1 van 2 Motorola Moto E6 Play Fingerprint Scanner Replacement: stap 3, afbeelding 2 van 2
    • With the angled tweezers, remove the black cover to reveal the motherboard underneath.
    • Remove the black piece cover with caution to avoid puncturing the motherboard with the tweezers.
  4. Motorola Moto E6 Play Fingerprint Scanner Replacement: stap 4, afbeelding 1 van 3 Motorola Moto E6 Play Fingerprint Scanner Replacement: stap 4, afbeelding 2 van 3 Motorola Moto E6 Play Fingerprint Scanner Replacement: stap 4, afbeelding 3 van 3
    • The bottom plastic piece covering the daughterboard can be seen by peeling back the tape covering the bottom section of the phone below the battery.
    • To remove the cover, unscrew the six black 3.45 mm Phillips screws holding the cover in place using the Phillips #0 screwdriver.
  5. Motorola Moto E6 Play Fingerprint Scanner Replacement: stap 5, afbeelding 1 van 2 Motorola Moto E6 Play Fingerprint Scanner Replacement: stap 5, afbeelding 2 van 2
    • Remove the black cover piece using the angled tweezers.
  6. Motorola Moto E6 Play Fingerprint Scanner Replacement, Fingerprint Scanner: stap 6, afbeelding 1 van 2 Motorola Moto E6 Play Fingerprint Scanner Replacement, Fingerprint Scanner: stap 6, afbeelding 2 van 2
    • Use the angled tweezers to pry off the metal head of the connecting piece from the main motherboard assembly.
  7. Motorola Moto E6 Play Fingerprint Scanner Replacement: stap 7, afbeelding 1 van 2 Motorola Moto E6 Play Fingerprint Scanner Replacement: stap 7, afbeelding 2 van 2
    • Use the angled tweezers to pull up on the two tabs connecting the scanner to the back plastic panel, and disconnect the fingerprint scanner from the back of the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Archer Leida
112 Reputatie
1 Handleiding geschreven
Cal Poly, Team S22-G4, Regan Winter 2020 Lid van Cal Poly, Team S22-G4, Regan Winter 2020
CPSU-REGAN-W20S22G4
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 369
