Inleiding
This guide shows how to replace the charging dock on the Motorola Moto E6. It should be replaced if the device is unable to charge when plugged in or if the device is overheating while charging. Replacing the charging dock will also replace the microphone on the bottom of the phone.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Wat je nodig hebt
Begin by prying open the bottom right of the device using the plastic opening tool.
Work your way around the edge of the device, slowly prying open the casing until it pops off.
Remove the seven 3.8 mm T4 screws on the piece located below the battery compartment.
6 andere personen hebben deze handleiding voltooid.
