Ga door naar hoofdinhoud
Motorola Moto E6 Charging Dock Replacement
Wat je nodig hebt
  1. Motorola Moto E6 Charging Dock Replacement, Back Cover: stap 1, afbeelding 1 van 2 Motorola Moto E6 Charging Dock Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Begin by prying open the bottom right of the device using the plastic opening tool.
    • Work your way around the edge of the device, slowly prying open the casing until it pops off.
  2. Motorola Moto E6 Charging Dock Replacement, Battery: stap 2, afbeelding 1 van 1
    • Use the opening tool on the divot located below the battery to pop it out.
  3. Motorola Moto E6 Charging Dock Replacement, Charging Dock: stap 3, afbeelding 1 van 1
    • Remove the seven 3.8 mm T4 screws on the piece located below the battery compartment.
  4. Motorola Moto E6 Charging Dock Replacement: stap 4, afbeelding 1 van 1
    • Begin prying off the bottom piece with the opening tools on the divot located at the bottom left.
    • Work your way around the piece until it pops off.
  5. Motorola Moto E6 Charging Dock Replacement: stap 5, afbeelding 1 van 1
    • Remove the press fit cable at the top of the charging dock with the plastic opening tool.
    • Remove the coaxial cable using the plastic opening tool.
  6. Motorola Moto E6 Charging Dock Replacement: stap 6, afbeelding 1 van 1
    • Remove the two 1.1 mm T4 Torx screws on the bottom right and top left sides of the charging dock.
    • Remove the charging dock by hand.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Matthew Zelten
471 Reputatie
3 handleidingen geschreven
Cal Poly, Team S2-G3, White Winter 2020 Lid van Cal Poly, Team S2-G3, White Winter 2020
CPSU-WHITE-W20S2G3
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 28
Altijd: 2,818
