Inleiding
For the official, updated iFixit guide, click here. This guide is archived for historical purposes.
This relatively moderate guide will walk you through with replacing the motherboard of your device. Sit tight as you'll be spending some time unscrewing a lot of screws and disconnecting connectors.
Wat je nodig hebt
Insert the spudger into the notch on the corner of the phone and lift up to remove the back case.
Use the T4 Torx Screwdriver to remove the 17 3.2 mm screws in the back panel covering the battery.
What do you do if the screws to tight and you can not unscrew them… Also the head of the screws too soft and damages easily.. I got few screws damaged, simply will probably need to use drill to get them out or something…
Wedge the spudger between the battery and the phone to lift the battery up and remove the battery. There will be slight resistance to this but the battery will not be damaged by this. It is just the adhesive tape.
Use a pair of tweezers to peel up the copper tape that covers the rear camera flex connector.
Fold the copper tape out of the way.
Use the T4 Torx Screwdriver to remove the 2 3.2 mm screws circled in the image.
Use the Spudger to lift up and detach the Main Flex Cable from the Motherboard.
10 andere personen hebben deze handleiding voltooid.
2 opmerkingen
guide states that there are 17 screws to remove (step 2) but there are 20 screws circled… Counting is hard I guess?
From step 9 it’s another phone. I’m guessing E4 (regular) but they are not the same. The vibration motor, second sim tray, and many other components disappear suddenly. Mixing different phones is very irresponsable and lazy.
