Ga door naar hoofdinhoud
Motorola Moto E4 Motherboard Replacement
Wat je nodig hebt
  1. Motorola Moto E4 Motherboard Replacement, Remove the rear cover: stap 1, afbeelding 1 van 2 Motorola Moto E4 Motherboard Replacement, Remove the rear cover: stap 1, afbeelding 2 van 2
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Motherboard Replacement, Remove the motherboard cover: stap 2, afbeelding 1 van 2 Motorola Moto E4 Motherboard Replacement, Remove the motherboard cover: stap 2, afbeelding 2 van 2
    • The battery is shown inserted in the Moto E4, but it should be removed before performing the following step.
    • Remove all nine 4 mm Phillips screws from the top plastic cover.
  3. Motorola Moto E4 Motherboard Replacement: stap 3, afbeelding 1 van 2 Motorola Moto E4 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Gently pry up the plastic cover using a plastic opening tool.
    • Start by inserting the tool under the cover's right edge, as indicated by the first picture.
    • Pry up, and continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
  4. Motorola Moto E4 Motherboard Replacement: stap 4, afbeelding 1 van 3 Motorola Moto E4 Motherboard Replacement: stap 4, afbeelding 2 van 3 Motorola Moto E4 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • This step can be skipped if you are only removing the front-facing camera. For all other repairs, continue as follows.
    • Disconnect the rear-facing camera by prying straight up on the connector on its right side.
    • Remove the rear-facing camera from the Moto E4.
  5. Motorola Moto E4 Motherboard Replacement, Remove the motherboard: stap 5, afbeelding 1 van 2 Motorola Moto E4 Motherboard Replacement, Remove the motherboard: stap 5, afbeelding 2 van 2
    • Disconnect the display cable by prying it straight up from the motherboard.
  6. Motorola Moto E4 Motherboard Replacement: stap 6, afbeelding 1 van 2 Motorola Moto E4 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Unlock the ZIF connector for the side buttons by prying up the black locking flap opposite the cable.
    • Pull the cable carefully toward the edge of the phone to slide it from its socket.
  7. Motorola Moto E4 Motherboard Replacement: stap 7, afbeelding 1 van 2 Motorola Moto E4 Motherboard Replacement: stap 7, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Disconnect the antenna cable by sliding a plastic pry tool or fine tweezers under the wire close to its socket, and then prying straight up.
  8. Motorola Moto E4 Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove the two 3.1 mm long Phillips screws securing the motherboard.
  9. Motorola Moto E4 Motherboard Replacement: stap 9, afbeelding 1 van 2 Motorola Moto E4 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Grab the top edge of the motherboard and lift to hinge it upward (but don't try to fully remove it). While doing so, keep all other cables clear of the motherboard.
    • Use a spudger or other fine-tip pry tool to pry off and disconnect the last remaining ribbon cable on the underside of the motherboard.
    • Remove the Moto E4 motherboard.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Nate Tjepkema
1.236 Reputatie
7 handleidingen geschreven
Cal Poly, Team S2-G4, White Winter 2019 Lid van Cal Poly, Team S2-G4, White Winter 2019
CPSU-WHITE-W19S2G4
4 Leden
22 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 2,893
