Ga door naar hoofdinhoud
Motorola Moto E4 Motherboard Cover Replacement
Wat je nodig hebt
  1. Motorola Moto E4 Motherboard Cover Replacement, Remove the rear cover: stap 1, afbeelding 1 van 2 Motorola Moto E4 Motherboard Cover Replacement, Remove the rear cover: stap 1, afbeelding 2 van 2
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Motherboard Cover Replacement, Motherboard Cover: stap 2, afbeelding 1 van 2 Motorola Moto E4 Motherboard Cover Replacement, Motherboard Cover: stap 2, afbeelding 2 van 2
    • Remove all nine 4mm screws from the top plastic cover with a Phillips driver.
  3. Motorola Moto E4 Motherboard Cover Replacement: stap 3, afbeelding 1 van 2 Motorola Moto E4 Motherboard Cover Replacement: stap 3, afbeelding 2 van 2
    • Gently pry up the plastic cover from the gap between it and the phone edge.
    • Start on the right side as indicated by the first picture.
    • Continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
Conclusie
Nate Tjepkema
1.236 Reputatie
7 handleidingen geschreven
Cal Poly, Team S2-G4, White Winter 2019 Lid van Cal Poly, Team S2-G4, White Winter 2019
CPSU-WHITE-W19S2G4
4 Leden
22 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 604
