Ga door naar hoofdinhoud
Motorola Moto E4 Front Facing Camera Replacement
Wat je nodig hebt
  1. Motorola Moto E4 Front Facing Camera Replacement, Remove the rear cover: stap 1, afbeelding 1 van 2 Motorola Moto E4 Front Facing Camera Replacement, Remove the rear cover: stap 1, afbeelding 2 van 2
    • Before removing the battery, power off your Moto E4.
    • Remove the plastic cover by gently prying it up from the notch at the bottom right corner of the phone.
    • With the phone face down, lift the battery up by the labeled tab and remove it from the device.
  2. Motorola Moto E4 Front Facing Camera Replacement, Motherboard Cover: stap 2, afbeelding 1 van 2 Motorola Moto E4 Front Facing Camera Replacement, Motherboard Cover: stap 2, afbeelding 2 van 2
    • Remove all nine 4mm screws from the top plastic cover with a Phillips driver.
  3. Motorola Moto E4 Front Facing Camera Replacement: stap 3, afbeelding 1 van 2 Motorola Moto E4 Front Facing Camera Replacement: stap 3, afbeelding 2 van 2
    • Gently pry up the plastic cover from the gap between it and the phone edge.
    • Start on the right side as indicated by the first picture.
    • Continue prying around the rest of the cover in a counter clockwise path.
    • Once loose, remove the plastic cover from the phone.
  4. Motorola Moto E4 Front Facing Camera Replacement, Front Facing Camera: stap 4, afbeelding 1 van 2 Motorola Moto E4 Front Facing Camera Replacement, Front Facing Camera: stap 4, afbeelding 2 van 2
    • Detach the front facing cable ribbon connector using an iFixit opening tool and lift the camera out of position.
    • To completely remove the front facing camera from the phone, the copper colored adhesive must be torn. The camera will still with the adhesive removed, but there may be unknown side effects.
Conclusie
Nate Tjepkema
1.236 Reputatie
7 handleidingen geschreven
Cal Poly, Team S2-G4, White Winter 2019 Lid van Cal Poly, Team S2-G4, White Winter 2019
CPSU-WHITE-W19S2G4
4 Leden
22 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 10
Altijd: 453
