Inleiding
The battery on this phone is covered by a plastic casing and will require the removal of some screws and plastic parts.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
If your battery is swollen, take appropriate precautions.
Wat je nodig hebt
To remove the back cover, start at one corner and stick the plastic opening tool under the cover and pry it away from the phone.
With the plastic opening tool, pry all the way around the phone while lifting up on the cover.
36 andere personen hebben deze handleiding voltooid.
7 opmerkingen
is it possible to fit Moto 2 gen battery into Moto 1 gen phone ?
This worked very well for me, many thanks!
which battery type or brand should we purchase????????
Excellent, clear instructions!
Works perfectly! Wonderful illustrations & text guide. (As long as you use the recommended tools).
Be aware — these instructions don’t apply to the 2nd generation Moto E. I discovered this when I couldn’t get the back cover off. It’s friction-fitted on the Gen 1, apparently, but glued on with the Gen 2. The rest of the procedure is also far more complex for the Gen 2.
