Ga door naar hoofdinhoud
Motorola Moto 360 Rear Cover Replacement
Wat je nodig hebt
  1. Motorola Moto 360 Rear Cover Replacement, Rear Cover: stap 1, afbeelding 1 van 1
    • Set the watch face down on a flat surface.
    • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
  2. Motorola Moto 360 Rear Cover Replacement: stap 3, afbeelding 1 van 2 Motorola Moto 360 Rear Cover Replacement: stap 3, afbeelding 2 van 2
    • Gently slide the blue opening pick between the rear cover and the metal casing.
    • The rear cover is extremely fragile. Be very delicate when using the opening pick.
    • Work your way entirely around the rear cover.
    • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
  3. Motorola Moto 360 Rear Cover Replacement: stap 4, afbeelding 1 van 1
    • Once the adhesive has been successfully loosened, gently pull the rear cover off.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Cole Twitchell
1.688 Reputatie
2 handleidingen geschreven
Cal Poly, Team 17-32, Amido Winter 2015 Lid van Cal Poly, Team 17-32, Amido Winter 2015
CPSU-AMIDO-W15S17G32
4 Leden
18 handleidingen geschreven
Één opmerking
How does this *rear cover replacement* count as "no parts required"?
Kyle Mitchell - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 14
Altijd: 12,808
