Ga door naar hoofdinhoud
Motorola Moto 360 O-Ring Replacement
Wat je nodig hebt
  1. Motorola Moto 360 O-Ring Replacement, Rear Cover: stap 1, afbeelding 1 van 1
    • Set the watch face down on a flat surface.
    • Place the heated iOpener on the face of the rear cover to loosen the adhesive underneath.
  2. Motorola Moto 360 O-Ring Replacement: stap 3, afbeelding 1 van 2 Motorola Moto 360 O-Ring Replacement: stap 3, afbeelding 2 van 2
    • Gently slide the blue opening pick between the rear cover and the metal casing.
    • The rear cover is extremely fragile. Be very delicate when using the opening pick.
    • Work your way entirely around the rear cover.
    • It may take several attempts of reheating the adhesive to get the rear cover loose enough to pull off.
  3. Motorola Moto 360 O-Ring Replacement: stap 4, afbeelding 1 van 1
    • Once the adhesive has been successfully loosened, gently pull the rear cover off.
  4. Motorola Moto 360 O-Ring Replacement, O-Ring: stap 5, afbeelding 1 van 2 Motorola Moto 360 O-Ring Replacement, O-Ring: stap 5, afbeelding 2 van 2
    • To get to the O-Ring, use the Jimmy to gently pry off the rear housing.
  5. Motorola Moto 360 O-Ring Replacement: stap 6, afbeelding 1 van 1
    • Pinch the green rubber O-Ring and slide it off of the watch.
    • The O-Ring is delicate and is easily severed. Use care around sharp objects.
Conclusie
Jake Steinorth
149 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-32, Amido Winter 2015 Lid van Cal Poly, Team 17-32, Amido Winter 2015
CPSU-AMIDO-W15S17G32
4 Leden
18 handleidingen geschreven
3 opmerkingen
Where can you get your hands on a replacement o'ring?!
James S - Antwoord
I broke my o-ring. Any ideas where I could get a raplacement?
Simon Hölz - Antwoord
i think you should not take the o ring. i was replaceing the battery without take the O ring
cahyanto emanuel nur - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 2,715
