Ga door naar hoofdinhoud
Motorola Moto 360 Case Locking Fastener Replacement
Wat je nodig hebt
  1. Motorola Moto 360 Case Locking Fastener Replacement, Wrist Strap: stap 1, afbeelding 1 van 1
    • Locate the spring-loaded pin that attaches the wrist strap to the watch.
    • There is a tiny groove on the end of the pin. This is where you will place the tweezers.
  2. Motorola Moto 360 Case Locking Fastener Replacement: stap 2, afbeelding 1 van 1
    • Take care not to lose the spring-loaded pin when removing the strap.
    • Use the tweezers to compress the spring-loaded pin so the strap can be removed.
  3. Motorola Moto 360 Case Locking Fastener Replacement: stap 3, afbeelding 1 van 2 Motorola Moto 360 Case Locking Fastener Replacement: stap 3, afbeelding 2 van 2
    • Pull the wristband away from the watch face.
  4. Motorola Moto 360 Case Locking Fastener Replacement, Case Locking Fasteners: stap 4, afbeelding 1 van 1
    • Locate the rectangular end of the fastener inside the wrist strap mounting pocket.
  5. Motorola Moto 360 Case Locking Fastener Replacement: stap 5, afbeelding 1 van 2 Motorola Moto 360 Case Locking Fastener Replacement: stap 5, afbeelding 2 van 2
    • Push the point of the pin in behind the fastener and pry it out. There is a notch near the end of the fastener which will engage the pin. Once the end pops out, the fastener will slide out of the slot easliy. Repeat to remove all four of them.
    • That's it. Now the two halves of the watch can be easily separated by just pulling gently with your fingers.
    This is a terribly useless picture
    Myk Dowling - Antwoord
Conclusie
18 andere personen hebben deze handleiding voltooid.
Chris K.
661 Reputatie
1 Handleiding geschreven
9 opmerkingen
I lost my fasteners... where can I buy more?
thiagopimenta - Antwoord
One misleading thing about this guide: pictures show the back cover taken off, while in fact you don't need to do this -- just take out the fasteners.
Дмитрий Трубин (Dmitry Trubin) - Antwoord
Absolutely correct, you don't need to heat or take the back off. I will say though that getting those clips out was damnably fiddly for me.
Ethan Duffy -
ou peut acheter Case Locking Fastener Replacement pour moto360 mon bracelet tien pas
svp chez besoin case locking fastener
abellegarde - Antwoord
don't remove the back!
follow this video for removing the locking pins.
I did it, so can you!
https://www.youtube.com/watch?v=Jw3n5qbG...
davidlanchart - Antwoord
NO! YOU DON”T NEED TO REMOVE THE CERAMIC BACK AT ALL!!!!!
You can safely remove all 4 pins by sliding a thin piece of plastic or metal down the inside of the case to slide the pins out
Bernard McGrath - Antwoord
So I lost one of those clips, it shot across the room when I was reinstalling it. Any idea where to get new clips or a suggested substitution.
Chad Yrigoyen - Antwoord
I’m looking for replacement retaining clips also. I’ve already opened it up once to replace the battery, but nicked the o-ring in the process, and some moisture got in. Have to replace my screen now. I found replacement o-rings (and front face assemblies with screen) on Amazon, but haven’t found retaining clips yet. I lost one taking it apart to get ready for the screen replacement.
Noah Erickson - Antwoord
I tried following this guide and wrecked my watch. I would not attempt prizing the pins out if you have poor eyesight,
I had the hook in the watch strap pin hole instead of by the securing pin , Gave it a light pull and pulled part of the watch away and now the strap pin has nothing to sit in. Much better to slide the pins out using a thin guitar pick or similar. as in this video tutorial I found a little too late. https://www.youtube.com/watch?v=wl61mDJl...
dean12665 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 7,511
