Ga door naar hoofdinhoud
Motorola Moto 360 3rd Gen Power Button Replacement
Wat je nodig hebt
  1. Motorola Moto 360 3rd Gen Power Button Replacement, Lower Case: stap 1, afbeelding 1 van 2 Motorola Moto 360 3rd Gen Power Button Replacement, Lower Case: stap 1, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Halberd Spudger
    $2.99
    • Use a T4 Torx screwdriver to remove the four 4.2 mm screws securing the lower case.
    • Gently pry the case open with a halberd spudger if the case will not release after removing the bolts.
    • Do not remove the lower case completely yet; this could damage cables connected to the lower case.
  2. Motorola Moto 360 3rd Gen Power Button Replacement: stap 2, afbeelding 1 van 1
    • Raise the cover without straining the connected ribbon cable.
    • Disconnect the ribbon cable from the motherboard with a halberd spudger.
  3. Motorola Moto 360 3rd Gen Power Button Replacement, Power Button: stap 3, afbeelding 1 van 2 Motorola Moto 360 3rd Gen Power Button Replacement, Power Button: stap 3, afbeelding 2 van 2
    • Disconnect the right (small, black head) and bottom right ribbons (wide, orange head).
    • No need to disconnect the left or bottom left ribbons.
  4. Motorola Moto 360 3rd Gen Power Button Replacement: stap 4, afbeelding 1 van 3 Motorola Moto 360 3rd Gen Power Button Replacement: stap 4, afbeelding 2 van 3 Motorola Moto 360 3rd Gen Power Button Replacement: stap 4, afbeelding 3 van 3
    • Gently remove the motherboard using the spudger tool.
    • The best area to pry is at the bottom of the motherboard, right under one of the ribbons that was just disconnected.
  5. Motorola Moto 360 3rd Gen Power Button Replacement: stap 5, afbeelding 1 van 2 Motorola Moto 360 3rd Gen Power Button Replacement: stap 5, afbeelding 2 van 2
    • While pushing the power button inwards, use tweezers to remove the c-clamp.
    • The c-clamp is a very tiny object; be cautious of losing it.
    • Remove the power button.
  6. Motorola Moto 360 3rd Gen Power Button Replacement: stap 6, afbeelding 1 van 2 Motorola Moto 360 3rd Gen Power Button Replacement: stap 6, afbeelding 2 van 2
    • Insert the new power button in place of the old power button.
    • Attach the c-clamp back around the power button while it is being pushed inwards.
Conclusie
Gage Kosnik
118 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 30
Altijd: 179
