Ga door naar hoofdinhoud
Wat je nodig hebt
Deze demontage is geen reparatiehandleiding. Om je Motorola MOTOACTIV W450 te repareren, gebruik onze reparatiehandleidingen.
    1. Motorola MOTOACTIV W450 Teardown, A Quick Look at the Phone: stap 1, afbeelding 1 van 3 Motorola MOTOACTIV W450 Teardown, A Quick Look at the Phone: stap 1, afbeelding 2 van 3 Motorola MOTOACTIV W450 Teardown, A Quick Look at the Phone: stap 1, afbeelding 3 van 3
      • My Motorola MOTOACTV is a tiny bit broken... but it’ll do. (I did NOT break it from opening, I broke it from anger... yeah...)
      Vraag FixBot
      Voeg opmerking toe
    2. Motorola MOTOACTIV W450 Teardown, Battery Removal: stap 2, afbeelding 1 van 2 Motorola MOTOACTIV W450 Teardown, Battery Removal: stap 2, afbeelding 2 van 2
      • First, open the back of the phone by pushing up the battery door. Then, carefully remove the battery.
      • Make sure the device is off to prevent damage.
      • DO NOT puncture the battery as this may result in an explosion.
      Vraag FixBot
      Voeg opmerking toe
    3. Motorola MOTOACTIV W450 Teardown, The First Screws: stap 3, afbeelding 1 van 3 Motorola MOTOACTIV W450 Teardown, The First Screws: stap 3, afbeelding 2 van 3 Motorola MOTOACTIV W450 Teardown, The First Screws: stap 3, afbeelding 3 van 3
      • Now we will remove the first screws. You will need a T5 Torx screwdriver or screwdriver bit to remove the four screws on the back. One of the screws is hidden underneath a black plastic circle, remove that.
      • DO NOT remove the back of the phone yet.
      Vraag FixBot
      Voeg opmerking toe
    4. Motorola MOTOACTIV W450 Teardown, Next Screws: stap 4, afbeelding 1 van 3 Motorola MOTOACTIV W450 Teardown, Next Screws: stap 4, afbeelding 2 van 3 Motorola MOTOACTIV W450 Teardown, Next Screws: stap 4, afbeelding 3 van 3
      • After the first screws are removed, let’s take a look at the front. On the bottom of the front, there is a plastic cover blocking two screws. Work your way around the edges of the cover with an opening tool to remove it, then lift the cover and remove the two remaining external Torx screws.
      Vraag FixBot
      Voeg opmerking toe
    5. Motorola MOTOACTIV W450 Teardown, Opening Time!: stap 5, afbeelding 1 van 2 Motorola MOTOACTIV W450 Teardown, Opening Time!: stap 5, afbeelding 2 van 2
      • Now to the fun part, opening the phone! Use an opening tool and work your way around the edges of the back cover. Then lift it and we’re in!
      Vraag FixBot
      Voeg opmerking toe
    6. Motorola MOTOACTIV W450 Teardown, A Few Removable Components: stap 6, afbeelding 1 van 2 Motorola MOTOACTIV W450 Teardown, A Few Removable Components: stap 6, afbeelding 2 van 2
      • Now if we take a look at the back of the back cover, we have a vibration motor and a microphone. Simply pull them out, CAREFULLY.
      Vraag FixBot
      Voeg opmerking toe
    7. Motorola MOTOACTIV W450 Teardown, Circuit Board: stap 7, afbeelding 1 van 3 Motorola MOTOACTIV W450 Teardown, Circuit Board: stap 7, afbeelding 2 van 3 Motorola MOTOACTIV W450 Teardown, Circuit Board: stap 7, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Now back to the phone. We are now at the circuit board. There is one connection to the screen on the back of the board (see pictures). We need to separate it from the board. Use tweezers to carefully lift the click connector. Next, there are two clips on the board. Use tweezers to push one in, then push the other in and lift the board.
      Vraag FixBot
      Voeg opmerking toe
    8. Motorola MOTOACTIV W450 Teardown, Board Parts: stap 8, afbeelding 1 van 2 Motorola MOTOACTIV W450 Teardown, Board Parts: stap 8, afbeelding 2 van 2
      • If we flip over the board, there are some removable parts. 1: The rubber keypad buttons. Simply pull them off as they are only glued a little. 2: The phone call mic. Pull up on the little yellow strip of rubber to remove. Don’t panic when you see the bottom of the mic, it looks like you pulled out the soldering, but you didn’t, just a connector!
      Vraag FixBot
      Voeg opmerking toe
    9. Motorola MOTOACTIV W450 Teardown, Going Deeper: stap 9, afbeelding 1 van 3 Motorola MOTOACTIV W450 Teardown, Going Deeper: stap 9, afbeelding 2 van 3 Motorola MOTOACTIV W450 Teardown, Going Deeper: stap 9, afbeelding 3 van 3
      • As we look into the back of the phone again, you should see those pesky clips from step 7. We can take those little guys out! Just push on the back of it and use your fingernail to pull up on the gold bar. Now you can take out the volume button by pushing it on from the outside of the phone.
      Vraag FixBot
      Voeg opmerking toe
    10. Motorola MOTOACTIV W450 Teardown, Screen!: stap 10, afbeelding 1 van 3 Motorola MOTOACTIV W450 Teardown, Screen!: stap 10, afbeelding 2 van 3 Motorola MOTOACTIV W450 Teardown, Screen!: stap 10, afbeelding 3 van 3
      • Phew! We’ve done a lot of work on the bottom of the phone. Let’s go to the top with the screen! First, use tweezers to remove the yellow rubber coverings over the screws, then use your T5 Torx driver to remove all four screws. Now work your way around the screen edge with an opening tool, then lift the cover!
      Vraag FixBot
      Voeg opmerking toe
    11. Motorola MOTOACTIV W450 Teardown, Small Screen & Camera Removal: stap 11, afbeelding 1 van 3 Motorola MOTOACTIV W450 Teardown, Small Screen & Camera Removal: stap 11, afbeelding 2 van 3 Motorola MOTOACTIV W450 Teardown, Small Screen & Camera Removal: stap 11, afbeelding 3 van 3
      • Wow! There sure are a lot of connections to the screen! Let’s remove them! Use tweezers to lift the metal connector, lift the black lever on the plastic connectors and pull out the wires, and lift the maroon plastic connector. The two black plastic connectors connect the small front screen and the camera, so you will remove these after the wires.
      • We now have exposed the screens! Please be very careful not to crack or shatter them because the liquid crystal inside of the screens is TOXIC!
      Vraag FixBot
      Voeg opmerking toe
    12. Motorola MOTOACTIV W450 Teardown, Main Screen Removal: stap 12, afbeelding 1 van 3 Motorola MOTOACTIV W450 Teardown, Main Screen Removal: stap 12, afbeelding 2 van 3 Motorola MOTOACTIV W450 Teardown, Main Screen Removal: stap 12, afbeelding 3 van 3
      • Now, the moment we’ve been waiting for... THE MAIN SCREEN REMOVAL! Carefully lift the screen circuit board out, unlatch the two white clips and carefully lift the screen backlight off. Now remove the metal cover on the back of the screen, remove the glued-on wire, and ever so carefully, use an opening tool to go UNDER the screen and boom! It’s off!
      Vraag FixBot
      Voeg opmerking toe
    13. Motorola MOTOACTIV W450 Teardown, One Last Thing...: stap 13, afbeelding 1 van 1
      • Well... did you not break it? If not, pat yourself on the back or do a little happy dance because you're done! Thanks for following my first guide and comment if I missed something and it’ll be fixed right away! See you later!
      Vraag FixBot
      Voeg opmerking toe
Liam Kandell
1.309 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 30
Altijd: 970
