Ga door naar hoofdinhoud
Motorola MOTO W755 Cell Phone Functional Keypad Replacement
Wat je nodig hebt
  1. Motorola MOTO W755 Cell Phone Functional Keypad Replacement, Main Logic Board: stap 1, afbeelding 1 van 1
    • Using the T5 Torx-screwdriver, remove the four 5.5 mm screws on the back panel.
  2. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: stap 2, afbeelding 1 van 2 Motorola MOTO W755 Cell Phone Functional Keypad Replacement: stap 2, afbeelding 2 van 2
    • Using a plastic opening tool, carefully peel back the rubber strip located at the bottom of the keypad
    • Remove the two T5 Torx-screws underneath the rubber strip using the T5 Torx-screwdriver
  3. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: stap 3, afbeelding 1 van 3 Motorola MOTO W755 Cell Phone Functional Keypad Replacement: stap 3, afbeelding 2 van 3 Motorola MOTO W755 Cell Phone Functional Keypad Replacement: stap 3, afbeelding 3 van 3
    • Using the flat end of the plastic opening tool, insert it in the gap between the charging port and plastic at the bottom left side of the phone.
    • Slide the opening tool around the phone clockwise until you reach the audio port.
    • Twist the opening tool until the plastic pops off from the body of the phone. This make require a small amount of force.
  4. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: stap 4, afbeelding 1 van 1
    • Remove the plastic covering completely from the body of the phone.
  5. Motorola MOTO W755 Cell Phone Functional Keypad Replacement: stap 5, afbeelding 1 van 2 Motorola MOTO W755 Cell Phone Functional Keypad Replacement: stap 5, afbeelding 2 van 2
    • Using the plastic opening tool, carefully unclip the cable ribbon from the main logic board. Be sure not to tear it because the flex is very fragile.
    • Remove the main logic board.
  6. Motorola MOTO W755 Cell Phone Functional Keypad Replacement, Functional Keypad: stap 6, afbeelding 1 van 1
    • Lift the plastic cover of the keypad from the top of the main logic board and peel it off.
Conclusie
Roberta Glenn
43 Reputatie
4 handleidingen geschreven
Cal Poly, Team 1-3, Regan SU 2012 Lid van Cal Poly, Team 1-3, Regan SU 2012
CPSU-REGAN-SU12S1G3
2 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,966
