Inleiding
In the case of damage or a non-functioning camera on the baby monitor, this guide will show users how to disassemble their camera in order to replace the circuit board.
Wat je nodig hebt
Remove the two 5 mm Phillips #1 screws on the back of the camera.
Use a nylon spudger to remove the casing.
Use the nylon spudger to remove the circuit board from the plastic casing for the backside of the camera.
Remove the two 5 mm Phillips #1 screws on the black circle receiver housing.
Now that the black circle is detached, use a nylon spudger to remove the white plastic circle from the casing.
