Inleiding
You will start by following the guide to remove the bottom case of the lapdock. After doing this you will remove the screws from the trackpad frame and gain access to the trackpad itself. Then you will unplug the trackpad from the motherboard. Once all of this is done you will be able to remove the trackpad from the lapdock.
Wat je nodig hebt
To take off the Keyboard there are three tabs at the top of the Keyboard in the locations shown in the picture that you must press and unclip. They are located behind each of the keys that are removed.
Remove the five 1.2mm long screws with the PH0 screwdriver from track pad reinforcement frame.
