Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Push down on the silver tab located at the top center of the back of the Motorola K1m cellphone.
While pushing down on the silver tab, slide the back cover towards the silver tab.
Remove the back cover.
Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
Replace the old battery with the new battery.
Follow all of the steps to remove the battery in reverse order to reassemble.
