Ga door naar hoofdinhoud
Motorola Krzr K1m Battery Replacement
  1. Motorola Krzr K1m Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Motorola Krzr K1m Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Push down on the silver tab located at the top center of the back of the Motorola K1m cellphone.
  2. Motorola Krzr K1m Battery Replacement: stap 2, afbeelding 1 van 1
    • While pushing down on the silver tab, slide the back cover towards the silver tab.
    • Remove the back cover.
  3. Motorola Krzr K1m Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery by pulling the battery from the top corners labeled "Pull Here" located on either side of the top of the battery.
    • Replace the old battery with the new battery.
    • Follow all of the steps to remove the battery in reverse order to reassemble.
Conclusie
Jennifer Hudiono
42 Reputatie
4 handleidingen geschreven
Cal Poly, Team 11-1, Forte Winter 2010 Lid van Cal Poly, Team 11-1, Forte Winter 2010
CPSU-FORTE-W10S11G1
5 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 14
Altijd: 5,553
