Ga door naar hoofdinhoud
Motorola E815 Keypad Replacement
Wat je nodig hebt
  1. Motorola E815 Keypad Replacement, Battery: stap 1, afbeelding 1 van 1
    • Locate the back cover release slide.
    • Use your finger to slide it down.
  2. Motorola E815 Keypad Replacement: stap 2, afbeelding 1 van 1
    • Remove the back cover by pulling it away from the phone.
  3. Motorola E815 Keypad Replacement: stap 3, afbeelding 1 van 2 Motorola E815 Keypad Replacement: stap 3, afbeelding 2 van 2
    • Locate the battery removal slot.
    • Use your finger to pull the battery out from the top.
    • Remove the battery.
  4. Motorola E815 Keypad Replacement, Disassembling Motorola E815 Antenna: stap 4, afbeelding 1 van 1
    • Locate the antenna port on the top of the phone.
  5. Motorola E815 Keypad Replacement: stap 5, afbeelding 1 van 2 Motorola E815 Keypad Replacement: stap 5, afbeelding 2 van 2
    • Grip the plastic support post and unscrew the apparatus using a counterclockwise twist.
    • Pull the apparatus up and out of the phone.
  6. Motorola E815 Keypad Replacement, Keypad: stap 6, afbeelding 1 van 1
    • Locate the two screws on the backside of the phone.
    • Unscrew the two screws using a T6 Screwdriver.
  7. Motorola E815 Keypad Replacement: stap 7, afbeelding 1 van 3 Motorola E815 Keypad Replacement: stap 7, afbeelding 2 van 3 Motorola E815 Keypad Replacement: stap 7, afbeelding 3 van 3
    • Gently pull the top section of the phone upwards until you feel some resistance.
    • Locate the brown connector that runs from the top section of the phone to the circuit board under the keypad.
    • Using tweezers, gently pry the connector from the circuit board.
    • Carefully detach the two sections of the phone.
  8. Motorola E815 Keypad Replacement: stap 8, afbeelding 1 van 3 Motorola E815 Keypad Replacement: stap 8, afbeelding 2 van 3 Motorola E815 Keypad Replacement: stap 8, afbeelding 3 van 3
    • Using the blue pry tool, carefully pull the keypad frame away from the keypad.
    • Gently remove the keypad frame from the keypad.
    • Lift the silicone keypad cover off.
  9. Motorola E815 Keypad Replacement: stap 9, afbeelding 1 van 2 Motorola E815 Keypad Replacement: stap 9, afbeelding 2 van 2
    • Rotate the phone around so that you are looking at the battery cavity.
    • Locate the screws on the bottom base of the phone.
  10. Motorola E815 Keypad Replacement: stap 10, afbeelding 1 van 2 Motorola E815 Keypad Replacement: stap 10, afbeelding 2 van 2
    • Rotate the phone back to the front side.
    • Slowly lift the bottom portion of the keypad off of the phone until you feel resistance.
  11. Motorola E815 Keypad Replacement: stap 11, afbeelding 1 van 3 Motorola E815 Keypad Replacement: stap 11, afbeelding 2 van 3 Motorola E815 Keypad Replacement: stap 11, afbeelding 3 van 3
    • Using tweezers, carefully detach the yellow connector strip from the circuit board by lifting up.
    • Separate the keypad from the circuit board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Zoie E
603 Reputatie
5 handleidingen geschreven
Cal Poly, Team 14-8, Forte Winter 2011 Lid van Cal Poly, Team 14-8, Forte Winter 2011
CPSU-FORTE-W11S14G8
5 Leden
2 opmerkingen
We should have a motherboard replacement.
Santi12008 - Antwoord
We need to fullify more this content.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 2,045
