Inleiding
This guide shows you how to replace the camera as it may be damaged or malfunctioning. The removal of the camera itself is simple, but getting there can be tricky because of the motherboard. Carefully follow guide. Tools are required for this.
Wat je nodig hebt
Remove the circled screws using a T-5 torques. These screws will be 4.3 millimeters in length.
Using a prying tool, snap off the front casing on the top and bottom of the phone.
Be careful not to lose the small rubber piece that sits over the microphone.
Één opmerking
how do u get it back on when it dose not come back on
brianna
