Inleiding
This guide shows you how to replace the camera as it may be damaged or malfunctioning. The removal of the camera itself is simple, but getting there can be tricky because of the motherboard. Carefully follow guide. Tools are required for this.
Wat je nodig hebt
Remove the circled screws using a T-5 torques. These screws will be 4.3 millimeters in length.
Gereedschap gebruikt in deze stap:Tweezers$4.99
Using tweezers, remove cable from motherboard.
Één opmerking
how do u get it back on when it dose not come back on
brianna
