Onderdelen
Geen onderdelen nodig.
Follow removal of rear housing guide. This should be your starting point.
  • Follow removal of rear housing guide. This should be your starting point.
Voeg opmerking toe
Using your fingernail or an opening tool, peel back the first layer of tape, located toward the left side of the phone. The circuit wiring should peel away with the tape. If not, remove the circuit wiring from the terminal.
  • Using your fingernail or an opening tool, peel back the first layer of tape, located toward the left side of the phone. The circuit wiring should peel away with the tape. If not, remove the circuit wiring from the terminal.
Voeg opmerking toe
Peel away second layer of tape and smaller circuit wiring.
  • Peel away second layer of tape and smaller circuit wiring.
  • Use caution as this wiring is extremely fragile.
Voeg opmerking toe
Using tweezers, remove wire connecting motherboard to small circuitboard at the bottom right of camera housing. Remove each head of the wire individually. Using tweezers, remove wire connecting motherboard to small circuitboard at the bottom right of camera housing. Remove each head of the wire individually.
  • Using tweezers, remove wire connecting motherboard to small circuitboard at the bottom right of camera housing. Remove each head of the wire individually.
Voeg opmerking toe
Pry up motherboard using opening tool to pry circuitboard away from two clasps on the left side of phone.
  • Pry up motherboard using opening tool to pry circuitboard away from two clasps on the left side of phone.
Voeg opmerking toe
Pull camera up from rear housing of phone using fingers.
  • Pull camera up from rear housing of phone using fingers.
Voeg opmerking toe
Remove final circuit from terminal on the bottom side of the motherboard using the opening tool.
  • Remove final circuit from terminal on the bottom side of the motherboard using the opening tool.
Voeg opmerking toe
Completed.
  • Completed.
Voeg opmerking toe
Conclusie
Genevieve Abbiss
19 reputatie
2 handleidingen geschreven
Ohio State, Team 1-1, Buehl Fall 2012 Lid van Ohio State, Team 1-1, Buehl Fall 2012
OSU-BUEHL-F12S1G1
4 Leden
3 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 2
Altijd: 1,223
