Ga door naar hoofdinhoud
Motorola Droid X Camera Replacement
Wat je nodig hebt
  1. Motorola Droid X Camera Replacement, Battery: stap 1, afbeelding 1 van 2 Motorola Droid X Camera Replacement, Battery: stap 1, afbeelding 2 van 2
    • Locate the power button at the top of the phone. Depress power button for 2 seconds until a menu appears.
  2. Motorola Droid X Camera Replacement: stap 2, afbeelding 1 van 2 Motorola Droid X Camera Replacement: stap 2, afbeelding 2 van 2
    • Once the menu appears, select the "power off" option. Wait until the phone is completely off.
  3. Motorola Droid X Camera Replacement: stap 3, afbeelding 1 van 2 Motorola Droid X Camera Replacement: stap 3, afbeelding 2 van 2
    • Place thumb on the back cover, and push down towards the bottom of the device. Once the cover releases, pull it away from the phone and set it aside.
  4. Motorola Droid X Camera Replacement: stap 4, afbeelding 1 van 2 Motorola Droid X Camera Replacement: stap 4, afbeelding 2 van 2
    • Find the yellow pull tab located in the upper left corner. Pull the tab until the battery dislodges. Grab the battery by the raised edge, and remove it from the case.
  5. Motorola Droid X Camera Replacement: stap 5, afbeelding 1 van 1
    • The battery has been successfully removed.
  6. Motorola Droid X Camera Replacement, Motorola Droid X Rear Housing: stap 6, afbeelding 1 van 1
    • Remove the micro SD card from its connector.
  7. Motorola Droid X Camera Replacement: stap 7, afbeelding 1 van 3 Motorola Droid X Camera Replacement: stap 7, afbeelding 2 van 3 Motorola Droid X Camera Replacement: stap 7, afbeelding 3 van 3
    • Locate the seam between the back case and the end cover on the top edge of the phone.
    • Use the plastic opening tool to detach the two clips by wedging the tool into the right side of the seam and moving right to left. Once the cover comes off set it aside
  8. Motorola Droid X Camera Replacement: stap 8, afbeelding 1 van 3 Motorola Droid X Camera Replacement: stap 8, afbeelding 2 van 3 Motorola Droid X Camera Replacement: stap 8, afbeelding 3 van 3
    • Repeat step 2 on the bottom cover.
  9. Motorola Droid X Camera Replacement: stap 9, afbeelding 1 van 3 Motorola Droid X Camera Replacement: stap 9, afbeelding 2 van 3 Motorola Droid X Camera Replacement: stap 9, afbeelding 3 van 3
    • Use a T5 Torx screwdriver to remove the screws in each corner of the phone.
    • The screws are very small so make sure not to lose them.
  10. Motorola Droid X Camera Replacement: stap 10, afbeelding 1 van 2 Motorola Droid X Camera Replacement: stap 10, afbeelding 2 van 2
    • Flip the phone over and locate the screw on the middle of the left side. Unscrew it using the T5 Torx screwdriver and set it aside.
  11. Motorola Droid X Camera Replacement: stap 11, afbeelding 1 van 2 Motorola Droid X Camera Replacement: stap 11, afbeelding 2 van 2
    • Identify the screw located in the bottom right corner of the battery case. Remove the screw with a T5 (or in some cases T6) torx screwdriver and set it aside.
  12. Motorola Droid X Camera Replacement: stap 12, afbeelding 1 van 2 Motorola Droid X Camera Replacement: stap 12, afbeelding 2 van 2
    • Locate the seam along the right edge of the phone. Use the prying tool to disconnect the two clips along the edge.
  13. Motorola Droid X Camera Replacement: stap 13, afbeelding 1 van 3 Motorola Droid X Camera Replacement: stap 13, afbeelding 2 van 3 Motorola Droid X Camera Replacement: stap 13, afbeelding 3 van 3
    • Locate the two clips on the inside of the case and use the spudger tool to detach them from the case. To detach each clip, use the sharp end to press the small, black plastic in the center of the clip.
  14. Motorola Droid X Camera Replacement: stap 14, afbeelding 1 van 2 Motorola Droid X Camera Replacement: stap 14, afbeelding 2 van 2
    • After the clips are detached, remove the back case and set it aside.
  15. Motorola Droid X Camera Replacement, Motherboard: stap 15, afbeelding 1 van 1
    • Remove the screws along both sides of the motherboard using a T3 Torx screwdriver. On some phones this may require a #1 Phillips Screw Driver.
  16. Motorola Droid X Camera Replacement: stap 16, afbeelding 1 van 2 Motorola Droid X Camera Replacement: stap 16, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Carefully remove the white connecting wire from the motherboard using tweezers.
    • Use caution, this wire is delicate.
  17. Motorola Droid X Camera Replacement: stap 17, afbeelding 1 van 2 Motorola Droid X Camera Replacement: stap 17, afbeelding 2 van 2
    • Scrape away the electrical tape that covers the LCD and digitizer cable using the spudger tool or a fingernail.
  18. Motorola Droid X Camera Replacement: stap 18, afbeelding 1 van 1
    • Use the spudger tool to pop the Digitizer cable off of the motherboard.
  19. Motorola Droid X Camera Replacement: stap 19, afbeelding 1 van 1
    • Carefully flip the small white connector up and away from the motherboard.
  20. Motorola Droid X Camera Replacement: stap 20, afbeelding 1 van 1
    • Gently pull the flat gold cable out from the connector.
  21. Motorola Droid X Camera Replacement: stap 21, afbeelding 1 van 1
    • Carefully lift the motherboard and camera module up. Do not remove it from the phone!
  22. Motorola Droid X Camera Replacement: stap 22, afbeelding 1 van 1
    • Using the spudger tool, pop the black cable connector off of the motherboard.
  23. Motorola Droid X Camera Replacement: stap 23, afbeelding 1 van 1
    • It is to safe remove the motherboard from the phone.
  24. Motorola Droid X Camera Replacement, Camera: stap 24, afbeelding 1 van 1
    • Gently peel the camera's orange and gold connection cable from the motherboard.
  25. Motorola Droid X Camera Replacement: stap 25, afbeelding 1 van 1
    • Remove the black electrical tape covering the cameras connection cable.
  26. Motorola Droid X Camera Replacement: stap 26, afbeelding 1 van 1
    • Flip up the small white connector. Then gently pull the orange cable out of the connecter.
  27. Motorola Droid X Camera Replacement: stap 27, afbeelding 1 van 1
    • Reconnect the camera module by pushing the black end of the flat cable on the camera module into the white connector on the motherboard.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Sam Johnston
576 Reputatie
4 handleidingen geschreven
Cal Poly, Team 18-40, Regan Fall 2012 Lid van Cal Poly, Team 18-40, Regan Fall 2012
CPSU-REGAN-F12S18G40
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 27
Altijd: 2,368
