Ga door naar hoofdinhoud
Motorola Droid Turbo Dual LED Flash Board Replacement
Wat je nodig hebt
  1. Motorola Droid Turbo Dual LED Flash Board Replacement, Rear Case: stap 1, afbeelding 1 van 1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
    This di not work; I had to use a blow dryer.
    Caroline Downie - Antwoord
  2. Motorola Droid Turbo Dual LED Flash Board Replacement: stap 2, afbeelding 1 van 2 Motorola Droid Turbo Dual LED Flash Board Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
    I had to go around the case, starting on the non-button side, around the top and then the other side. This, unfortunately, pulled on the rear case, pressed the power button and turned the device back on. I would suggest starting on the button side and going around.
    Ryan Helinski - Antwoord
  3. Motorola Droid Turbo Dual LED Flash Board Replacement, Dual LED Flash Board: stap 3, afbeelding 1 van 2 Motorola Droid Turbo Dual LED Flash Board Replacement, Dual LED Flash Board: stap 3, afbeelding 2 van 2
    • Use a Jimmy to separate the dual LED flash board from the rear case.
    • The board is secured with some light adhesive, so some force may be required.
    No parts? Really?
    Rongwey - Antwoord
    What I meant to say was great job! Also I have a question about the adhesive pads holding the flash on. Shouldn't they be replaced as well? My flash wasn't working so I took the back off and cleaned the contacts and put it back together. It worked fine for a couple of days and went back to only blinking. The pads seem to be letting the flash part move with the chop motion to activate the flashlight,
    Rongwey - Antwoord
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Geoff Wacker
89.898 Reputatie
89 handleidingen geschreven
Één opmerking
Gostaria se possível alguem tenha o manual de serviço do Moto maxx XT 1225 ou 1254. Porf favor , ddani8260@gmail.com
Daniel Gomes - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 959
