Ga door naar hoofdinhoud
Motorola Droid RAZR Maxx Back Cover Replacement
Wat je nodig hebt
  1. Motorola Droid RAZR Maxx Back Cover Replacement, Taking off the Back Cover: stap 1, afbeelding 1 van 2 Motorola Droid RAZR Maxx Back Cover Replacement, Taking off the Back Cover: stap 1, afbeelding 2 van 2
    • Remove the SIM card.
    • Remove the microSD card.
    • Insert the plastic opening tool between the back cover and the front piece of the case, freeing the plastic clips between the phone.
    • Do this along the back right side of the phone cover until you reach the top.
  2. Motorola Droid RAZR Maxx Back Cover Replacement: stap 2, afbeelding 1 van 2 Motorola Droid RAZR Maxx Back Cover Replacement: stap 2, afbeelding 2 van 2
    • Use the plastic opening tool to carefully work your way around the top of the phone, freeing the plastic clips.
    • Be cautious when using the tool around the top of the device because the plastic case is very thin and could easily be cracked or snapped.
    • Continue using the tool and pry down the remaining side and the bottom of the phone.
  3. Motorola Droid RAZR Maxx Back Cover Replacement: stap 3, afbeelding 1 van 3 Motorola Droid RAZR Maxx Back Cover Replacement: stap 3, afbeelding 2 van 3 Motorola Droid RAZR Maxx Back Cover Replacement: stap 3, afbeelding 3 van 3
    • With all the plastic clips released, pull away the back cover from the phone to remove it.
    • The back cover is attached to the battery with a large amount of adhesive. Some force may be required to pull the back cover from the phone.
    • The back cover is very durable and will not break from some bending or pulling.
Conclusie
4 andere personen hebben deze handleiding voltooid.
sean crocker
341 Reputatie
1 Handleiding geschreven
USF Tampa, Team 14-6, Leahy Fall 2014 Lid van USF Tampa, Team 14-6, Leahy Fall 2014
USFT-LEAHY-F14S14G6
4 Leden
10 handleidingen geschreven
2 opmerkingen
Ok so I have the cover off of the back of my Droid Razr Maxx HD? But where is it that I can purchase the new back cover? I figured you guys would have at least a hyper link to somewhere I could buy it? Instead of just having instructions on how to remove the backing? Thanks Very Respectfully, Joey K
sailorjt1985 - Antwoord
I have same problem. Need new back cover.
TheShellex - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 11
Altijd: 2,794
