Ga door naar hoofdinhoud
Motorola Droid RAZR Back Cover Replacement
Wat je nodig hebt
  1. Motorola Droid RAZR Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 2 Motorola Droid RAZR Back Cover Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Insert a plastic opening tool between the back cover and rear case at the lower left edge of the back cover.
    • Pry the back cover up with the plastic opening tool to free the plastic clips.
    • Continue prying along the left edge of the back cover towards the top of the phone.
  2. Motorola Droid RAZR Back Cover Replacement: stap 2, afbeelding 1 van 3 Motorola Droid RAZR Back Cover Replacement: stap 2, afbeelding 2 van 3 Motorola Droid RAZR Back Cover Replacement: stap 2, afbeelding 3 van 3
    • Work the plastic opening tool across the top of the back case to free the plastic clips.
    • The top edge of the back case is very thin. Pry carefully to avoid cracking or snapping it.
    • Continue prying down the right side of the back cover to free the remaining clips.
  3. Motorola Droid RAZR Back Cover Replacement: stap 3, afbeelding 1 van 3 Motorola Droid RAZR Back Cover Replacement: stap 3, afbeelding 2 van 3 Motorola Droid RAZR Back Cover Replacement: stap 3, afbeelding 3 van 3
    • Pull the back cover away from the phone to remove it.
    • The back cover is attached to the battery with a generous amount of adhesive, so you may have to use quite a bit of force to separate the two pieces.
    • The battery must remain in the phone and not come off with the back cover or you will break the power lead.
    • Since the back cover is made of Kevlar, it can handle a fair amount of twisting and tugging without breaking.
Conclusie
7 andere personen hebben deze handleiding voltooid.
David Hodson
155.492 Reputatie
127 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 27
Altijd: 14,529
