Ga door naar hoofdinhoud
Motorola Droid Pro SD Card/SIM Card PCB Board Replacement
Wat je nodig hebt
  1. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the back cover using the thumb tab located on the bottom of the phone.
  2. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: stap 2, afbeelding 1 van 2 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery using the thumb tab.
  3. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: stap 3, afbeelding 1 van 2 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement, SD Card/SIM Card PCB Board: stap 3, afbeelding 2 van 2
    • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
  4. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: stap 4, afbeelding 1 van 3 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: stap 4, afbeelding 2 van 3 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: stap 4, afbeelding 3 van 3
    • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use extra force to unlock them.
    • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
  5. Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: stap 5, afbeelding 1 van 2 Motorola Droid Pro SD Card/SIM Card PCB Board Replacement: stap 5, afbeelding 2 van 2
    • Gently lift the SD & SIM card board (PCB) as shown.
    • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
Conclusie
Kyle Shays
836 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team 1-6, Miles Fall 2015 Lid van UMass Dartmouth, Team 1-6, Miles Fall 2015
UMASSD-MILES-F15S1G6
3 Leden
12 handleidingen geschreven
Één opmerking
Does the replacement board have to be from the same phone or does any sim board work from any phone as long as it's 3g
lisa marie - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 310
