Ga door naar hoofdinhoud
Motorola Droid Pro Motherboard Replacement
Wat je nodig hebt
  1. Motorola Droid Pro Motherboard Replacement, Battery: stap 1, afbeelding 1 van 1
    • Remove the back cover using the thumb tab located on the bottom of the phone.
  2. Motorola Droid Pro Motherboard Replacement: stap 2, afbeelding 1 van 2 Motorola Droid Pro Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery using the thumb tab.
  3. Motorola Droid Pro Motherboard Replacement, SD Card/SIM Card PCB Board: stap 3, afbeelding 1 van 2 Motorola Droid Pro Motherboard Replacement, SD Card/SIM Card PCB Board: stap 3, afbeelding 2 van 2
    • Using a T4 Torx driver, remove the eight 4 mm back panel screws.
  4. Motorola Droid Pro Motherboard Replacement: stap 4, afbeelding 1 van 3 Motorola Droid Pro Motherboard Replacement: stap 4, afbeelding 2 van 3 Motorola Droid Pro Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Use a plastic opening tool to open the phone along the sides between the front panel and the chrome trim.
    • It is held together by small clips that lock in. You may have to use extra force to unlock them.
    • Go around on all sides of the phone, unlocking the clips. Then pull the back panel off.
  5. Motorola Droid Pro Motherboard Replacement: stap 5, afbeelding 1 van 2 Motorola Droid Pro Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Gently lift the SD & SIM card board (PCB) as shown.
    • There is a ribbon cable attached underneath. Gently pull the PCB board away from the phone and it will detach easily.
  6. Motorola Droid Pro Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 2 Motorola Droid Pro Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Use your plastic opening tool to disconnect the motherboard/keyboard ribbon cable.
    • There are small tabs on the side of the connectors to wedge your tool under.
  7. Motorola Droid Pro Motherboard Replacement: stap 7, afbeelding 1 van 2 Motorola Droid Pro Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Use your plastic opening tool to disconnect the two ribbon cables at the top of the phone.
  8. Motorola Droid Pro Motherboard Replacement: stap 8, afbeelding 1 van 2 Motorola Droid Pro Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Disconnect the 2nd keyboard connector from the motherboard and remove it from its side holders.
    • This cable is fragile so be careful when disconnecting and moving it around.
  9. Motorola Droid Pro Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Use a T5 Torx Screwdriver to unscrew the 2mm screw.
  10. Motorola Droid Pro Motherboard Replacement: stap 10, afbeelding 1 van 3 Motorola Droid Pro Motherboard Replacement: stap 10, afbeelding 2 van 3 Motorola Droid Pro Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Remove the camera's rubber seal by pulling it off. It is not connected to anything.
  11. Motorola Droid Pro Motherboard Replacement: stap 11, afbeelding 1 van 2 Motorola Droid Pro Motherboard Replacement: stap 11, afbeelding 2 van 2
    • To remove the motherboard, pull it to the side. The camera that is connected to the motherboard does not pull straight up and out from its holder.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Richard Bellizzi
352 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-6, Miles Fall 2015 Lid van UMass Dartmouth, Team 1-6, Miles Fall 2015
UMASSD-MILES-F15S1G6
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 331
