Inleiding
Before continuing through the replacement process make sure you power down your devices and work in a clean area free of dirt. Also use a static band so you don't damage your device.
Wat je nodig hebt
Remove the back cover and battery by using the thumb tabs.
Pop out key board using a spudger on the marked points.
Once out you can pop the new keyboard in the opposite way you took it out.
Bijna klaar!
Conclusie
