Inleiding
The battery is responsible for most of your phone's functions. When the battery malfunctions, the phone may not function properly, and needs to be replaced.
If your battery is swollen, take appropriate precautions.
Wat je nodig hebt
Pry off the back case gently using the iFixit opening tool.
Use the T5 screw head to unscrew the 9 silver screws from the housing frame.
Carefully separate the housing frame from the motherboard.
11 andere personen hebben deze handleiding voltooid.
8 opmerkingen
There are a few things missing from this guide that should be included.
1) In additon to the 9 screws shown there are three more across the top of the housing frame. (Not all these screws are silver on some models.
2) The battery is not glued to the motherboard it is glued to the NFC antenna. Remove with care.
3) Both the antenna jack on the motherboard and the battery jack require the cable plug to pushed straight down.
4) The batteries come with a protective cover over the end of the connector remove before installing.
3) There is a metal strap not shown in the picture across the bottom of the battery that must be popped out. It pops out from one side and the you unhook the other side.
Fantastic, this was very helpful!
Note there are three screws along the top of the housing frame (similar to the three on the bottom) and one gold screw near the camera.
There are also two screws under the housing frame holding the motherboard down.
Thanks so much to the author and the first 2 commentators. All 3 helped make my 1st intricate repair a success! Along with a mini tool kit for cell phones. I like picture/text better than video. Thanks again. Danny North
The black screws can be difficult: I found a 1.5mm flat head was the only way to unscrew some of them- the torx T5 did not seem to bite.
Also... there are 2 large headed silver screws that need to be removed to tip up the motherboard to access the battery connector-The motherboard does not need to be removed- just tipped up to get at the connector. Also there is a brass colored screw that needs to come off with the first black and silver screws, or the frame can not be removed.
I finished everything, but now my screen won't turn on, and my phone keeps vibrating ever 10 seconds. What did I do wrong?
Everything works except now my headphone jack doesn't work. I see when I take it apart again that there is a flex cable that needs to either touch or attach to the motherboard. Which is it? Does it need to 'snap on' like the other flex cables? It is in a nearly impossible location to reach. Thanks!
Arielleeeee... Look at you! Look what a BICH you've become ! Children are coming here...watching at your SHAMELESSNESS !...and then imitate that f**** attitude ?! Shame on You !!! Remove this pervert pic for God sake !!! Don't you have A NORMAL ONE ?
Disgusting ! Nowadays no one even thinks about Children and harlotry that they have been watching all the time... DISGUSTING !!!
