Ga door naar hoofdinhoud
Motorola Droid MAXX 2 Screen Only Replacement
Wat je nodig hebt
  1. Motorola Droid MAXX 2 Screen Only Replacement, Battery: stap 1, afbeelding 1 van 1
    • Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
  2. Motorola Droid MAXX 2 Screen Only Replacement: stap 2, afbeelding 1 van 1
    • Pull the sim card tray up out of the phone
  3. Motorola Droid MAXX 2 Screen Only Replacement: stap 3, afbeelding 1 van 2 Motorola Droid MAXX 2 Screen Only Replacement: stap 3, afbeelding 2 van 2
    • Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
  4. Motorola Droid MAXX 2 Screen Only Replacement: stap 4, afbeelding 1 van 1
    • Remove the seventeen 3.2mm Torx T4 screws from the mid-frame.
    • These may be T3 screws. If you are having trouble unscrewing these, stop and try a T3 bit.
  5. Motorola Droid MAXX 2 Screen Only Replacement: stap 5, afbeelding 1 van 1
    • Pull the mid-frame off of the phone.
    • Keep track of the on/off and volume buttons when you take the phone apart because they are likely to fall out when the halves are separated.
  6. Motorola Droid MAXX 2 Screen Only Replacement: stap 6, afbeelding 1 van 3 Motorola Droid MAXX 2 Screen Only Replacement: stap 6, afbeelding 2 van 3 Motorola Droid MAXX 2 Screen Only Replacement: stap 6, afbeelding 3 van 3
    • Remove the static tape covering the two connectors.
    • Use a spudger to disconnect the battery cables from the motherboard.
    • If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
  7. Motorola Droid MAXX 2 Screen Only Replacement: stap 7, afbeelding 1 van 1
    • Remove the disconnected battery from the phone.
  8. Motorola Droid MAXX 2 Screen Only Replacement, Screen Assembly: stap 8, afbeelding 1 van 2 Motorola Droid MAXX 2 Screen Only Replacement, Screen Assembly: stap 8, afbeelding 2 van 2
    • We will be removing these 3 ribbon cables.
    • Using an opening pick, lift the grey tab on the rear camera's ZIF connector. Remove the ribbon cable and the camera.
    • Use tweezers to lift up on the grey latch on the ZIF connector.
    • Remove the ribbon cable from the ZIF connector.
  9. Motorola Droid MAXX 2 Screen Only Replacement: stap 9, afbeelding 1 van 2 Motorola Droid MAXX 2 Screen Only Replacement: stap 9, afbeelding 2 van 2
    • Use a pair of tweezers to lift up the black latch on the ZIF connector.
    • Pull the ribbon cable out of the ZIF connector.
  10. Motorola Droid MAXX 2 Screen Only Replacement: stap 10, afbeelding 1 van 3 Motorola Droid MAXX 2 Screen Only Replacement: stap 10, afbeelding 2 van 3 Motorola Droid MAXX 2 Screen Only Replacement: stap 10, afbeelding 3 van 3
    • Using a metal spudger, work your way around the perimeter of the main board and screen.
    • There is a lot of adhesive between the two pieces, so be careful to try to remove the adhesive slowly in order to not break anything.
  11. Motorola Droid MAXX 2 Screen Only Replacement, Screen Only: stap 11, afbeelding 1 van 2 Motorola Droid MAXX 2 Screen Only Replacement, Screen Only: stap 11, afbeelding 2 van 2
    • Use an opening pick or metal jimmy to carefully peel up a corner of this section of copper tape.
    • Slowly peel the entire piece of copper tape off of the frame, trying not to tear or kink it. Set aside and re-install after attaching new display.
    • Using the pointy tip of a spudger, detach these display cable tabs from the frame.
  12. Motorola Droid MAXX 2 Screen Only Replacement: stap 12, afbeelding 1 van 2 Motorola Droid MAXX 2 Screen Only Replacement: stap 12, afbeelding 2 van 2
    • Carefully peel up the bottom part of this piece of copper tape and fold it over.
    • Using the point of a spudger, detach this display cable tab from the frame.
    • The plastic edge around the digitizer is very fragile. Use caution when separating the adhesive.
    • Heat the top bezel to soften the adhesive and carefully start removing the display from the frame using a plastic opening picks and a metal jimmy as necessary.
    • The display cable is lightly adhered to the frame. Remove the display starting from the top.
Conclusie
Patrick
6.574 Reputatie
21 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 397
