Inleiding
This guide will show you how to replace the front camera on a Motorola Droid MAXX 2 smartphone.
Wat je nodig hebt
Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
Remove the static tape covering the two connectors.
Use a spudger to disconnect the battery cables from the motherboard.
If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
Bijna klaar!
Conclusie
